Clifford Alarm Help Please!!!
Supragaz
I have a Concept300 and need to make it less sensitive. It keeps going off when cars go past mine at speed. I have been told I can change the sensitivity using the keyfob.
Anyone know what I need to do please?
If not I think the neighbours are gonna start keying my car soon!!! :blink:
Thanks
Gaz
I've heard a lot of people say that. Sorry doesnt help you much I know!
How about calling a clifford installer tomorrow they should be able to tell you.
Yeah I know, cheers dude. My mate is having a 650 fitted next week so will sort it then. The neighbours will have to put up with it going off loads in the mean time :)
My 300 is getting ripped out as soon as I can afford something else. Biggest pile o shit I've ever had. Goes off by itself (continuously) even after checking itself for problems and finding none and recently the fcuking thing won't un-arm so I've been stuck out of my car. When it does let me in or I unlock the door and wait for it to decide to let me turn the siren off and start the car...it then won't lock when I get where I'm going.
No lie the best alarm I've ever had is a happy shopper £200 Laserline from Halfords on my old MkiV Escort 1.4l. Did it's job well and stopped it getting broken into and stolen on seperate occasions !
If it is anything like the concept 650 I have the instruction's for that?
Read the following instructions thoroughly for a full understanding of
how to properly adjust this sensor.
1. Disarm system
2. Transmit Channel 16. (Press cliff 3 times then *
1 time)
. The LED will turn on and the siren will chirp 1 time.
. Primary (full trigger) zone adjustment has now been entered.
. Primary zone can now be adjusted.
3. Adjusting Primary Zone
. Press (trunk) of the remote control to increase sensitivity.
. Press (*) of the remote control to decrease sensitivity.
. The sensor Primary zone can be tested at any time during
adjustment and will generate 1 siren chirp each time the zone is activated.
4. Press (**) to adjust Warn-Away zone
. Siren chirps 1 time.
. Warn-away Zone adjustment has now been entered.
. Warn-away Zone can now be adjusted.
5. Adjust Warn-away Zone
. Press (trunk)to increase sensitivity.
. Press (*)to decrease sensitivity.
. The sensor Warn-away zone can be tested at any time during adjustment
6. Press (lock/unlock) of the remote control to return to Primary zone
adjustment and lock in Warn Away zone setting.
. Siren chirps 2 times
. Primary zone can now be re-adjusted as described in
step 3.
. Or press (lock/unlock) again to lock in primary zone setting
and exit programming mode.
. The siren will chirp 3 times when sensor adjustment
mode has been exited.
. Auto-Scroll for adjusting sensitivity - press and
hold (trunk) or (*) to increase or decrease sensitivity
setting several levels rapidly.
1. Disarm system
1 time)
step 3.
Thanks mate ;)
  • 4 weeks later...
