NUTKIN Posted January 11, 2007 Share Posted January 11, 2007 Not sure if i need the whole rack or if the arms can be seperated from the rack. I have bent the arm an the track rod end can theses be replaced seperatly or is it the whole steering rack that i need. Please can someone advise me how much for a rack or seperate parts would be. Thanks NUTKIN Link to comment Share on other sites More sharing options...
Jake Posted January 11, 2007 Share Posted January 11, 2007 It's quite a straightforward job (unless you're a certain ex-trader I could mention ) Two bolts, one clamp, two track rod ends. It would take about an hour with the right tools. You'll need to get the tracking done ASAFP after fitting the new rack. Supra steering racks are very expensive new. Like over £600. Link to comment Share on other sites More sharing options...
NUTKIN Posted January 11, 2007 Author Share Posted January 11, 2007 But can i seperate the rack i know with some cars u can or is it one part an have to change the whole thing Link to comment Share on other sites More sharing options...
Rob Posted January 11, 2007 Share Posted January 11, 2007 Supra steering racks are very expensive new. Like over £600. A few years ago York Toyota quoted me £1200. Link to comment Share on other sites More sharing options...
Jake Posted January 11, 2007 Share Posted January 11, 2007 A few years ago York Toyota quoted me £1200.That's including fitting, right? Link to comment Share on other sites More sharing options...
Rob Posted January 11, 2007 Share Posted January 11, 2007 TBH, I never asked, I knew it was balls at the time and they were just throwing a belt and braces repair at me, i.e. the PS doesn't work, change the rack. Link to comment Share on other sites More sharing options...
johnd-mkiv Posted January 11, 2007 Share Posted January 11, 2007 got a steering rack for £60 if your interested Link to comment Share on other sites More sharing options...
Nic Posted January 11, 2007 Share Posted January 11, 2007 That's including fitting, right? Probably not, they are very expensive new from memory. Link to comment Share on other sites More sharing options...
Jake Posted January 11, 2007 Share Posted January 11, 2007 I know. They're a little over £600, as I said up there ^ Link to comment Share on other sites More sharing options...
Nic Posted January 11, 2007 Share Posted January 11, 2007 I know. They're a little over £600, as I said up there ^ Didn't see that Thought they were more than that TBH Link to comment Share on other sites More sharing options...
Rob Posted January 11, 2007 Share Posted January 11, 2007 I thought they were about £1200, Toyota quoted me that in York a few years ago. Link to comment Share on other sites More sharing options...
absz Posted January 11, 2007 Share Posted January 11, 2007 you can just undo the rod from the rack and replace it:) will save you replacing the whole thing. Link to comment Share on other sites More sharing options...
jamesmark Posted January 11, 2007 Share Posted January 11, 2007 Pete pointed this one out in my thread but I need the rear subframe Link Link to comment Share on other sites More sharing options...
JODY T Posted January 11, 2007 Share Posted January 11, 2007 As Abs said you can unscrew the ends from the rack... Ive done loads... If you have the correct size spanner (or a nice set of grips) its very easy.... But it is tight.. IF you take off the rack boot you will see where the arm is at its thickest point it has flat spots on each side... Tip remove the grease with a rag... Spanner wont slip as much... Easy job... Link to comment Share on other sites More sharing options...
