Guest Mike Leavy Posted June 12, 2004 Share Posted June 12, 2004 Hi guys. Thinking of fitting UK brakes to my 99 J spec Any idea who can do this, roughly how much it costs and also will they be ok if I also fit BBS RKII 18" alloys? Assume someone must have already done this? Link to comment Share on other sites More sharing options...
richy2jz-gte Posted June 12, 2004 Share Posted June 12, 2004 hasnt the the face lift j-spec already got uk spec breakes:conf: Link to comment Share on other sites More sharing options...
Guest Mike Leavy Posted June 12, 2004 Share Posted June 12, 2004 does it? first I've heard of it. I'd have thought unlikely since mine actually has 16" facelift wheels (fairly rare but did happen occasionally). Anyone know the answer? Link to comment Share on other sites More sharing options...
Zed Posted June 12, 2004 Share Posted June 12, 2004 Should be pretty obvious from looking at the existing brakes. If they have a flat surface with the 'supra' logo on them then they're uk spec brakes. The calaipers look like they are one big solid peice as opposed to the j-spec ones which look like they're made of a couple of pieces. Hope this helps Link to comment Share on other sites More sharing options...
Darren Posted June 12, 2004 Share Posted June 12, 2004 If it came with 16inch wheels you have J spec brakes... I think the last group buy for UK fronts was about £550? Then some braided lines would be nice £50 and then some pads and decent fluid...Any garage should be able to swap the disks and calipers fairly quickly...HTH Link to comment Share on other sites More sharing options...
Timwildman Posted June 12, 2004 Share Posted June 12, 2004 dangerous brain might have some uk spec brakes for sale. you should PM him. Link to comment Share on other sites More sharing options...
TRD3000GT Posted June 13, 2004 Share Posted June 13, 2004 nope coz I just did mine :-) Link to comment Share on other sites More sharing options...
richy2jz-gte Posted June 13, 2004 Share Posted June 13, 2004 probably dont then. just a bit more crap passed throught the poo spreader. i read it a couple of times on this forum somwhere Link to comment Share on other sites More sharing options...
SimonB Posted June 15, 2004 Share Posted June 15, 2004 Originally posted by richy2jz-gte probably dont then. just a bit more crap passed throught the poo spreader. i read it a couple of times on this forum somwhere The facelift RZ has big brakes and wheels, Recaro seats and is manual only. The facelift RZ-S does not (unless they have been added). Link to comment Share on other sites More sharing options...
Guest Mike Leavy Posted June 15, 2004 Share Posted June 15, 2004 ahhh. thats probably the answer then. U know if 18" BBS RXII's will fit over UK brakes if I upgrade? Any idea what size spacesaver wheel I would also need? Link to comment Share on other sites More sharing options...
dangerous brain Posted June 15, 2004 Share Posted June 15, 2004 Standard space saver should fit shouldn't it?? And yes I have a set of virtually new front UK brakes for sale when I get them off the car. I also have to get the passenger side disc checked as its been sat on it for a while. Link to comment Share on other sites More sharing options...
SimonB Posted June 15, 2004 Share Posted June 15, 2004 Yes, the standard spacesaver will fit. Don't know about the BBSs, sorry. They're not on the list of wheels known to fit, but that just means that nobody has got any and bigger brakes. Link to comment Share on other sites More sharing options...
dangerous brain Posted June 15, 2004 Share Posted June 15, 2004 See if you can borrow a rim, Find a local member with UK brakes Take the wheel over and see if it fits!!! Link to comment Share on other sites More sharing options...
