G9RGE Posted January 10, 2007 Share Posted January 10, 2007 Does anyone know how to connect Greddy emanage blue to greddy profec e01 boost controller. I have bought an external signal harness which has six wires. White Grey Green Black Dark Blue Light Blue Could anyone tell me which one connects to which? Link to comment Share on other sites More sharing options...
bondango Posted January 10, 2007 Share Posted January 10, 2007 Emanage Blue is connected to the E01 with a USB cable. The emanage can then use the E01 boost sensor to reference boost. you can also use the E01 as an emanage programmer too. The external signal cable you mention allows you to log 5v devices with the E01 such as TPS, AFR from a wideband with 5V output signal etc etc Link to comment Share on other sites More sharing options...
Homer Posted January 10, 2007 Share Posted January 10, 2007 There are also detailed guides on http://www.mohdparts.com Link to comment Share on other sites More sharing options...
JustGav Posted January 10, 2007 Share Posted January 10, 2007 Yup, EMB connects via the USBstyle cable (Please note, it is not a USB interface so don't try connect a laptop directly to it). I'm currently using mine purely as a boost controller because it isn't compatible with the EMU as far as I know which is a shame. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 10, 2007 Share Posted January 10, 2007 The connection from EO-1 to blue emanage is an A-B USB available at any PC shop, its just the data cable that is a Greddy generic type which comes with the software, although there was someone doing clone cables Link to comment Share on other sites More sharing options...
G9RGE Posted January 12, 2007 Author Share Posted January 12, 2007 Ok cheers guys thanks for all the advise Link to comment Share on other sites More sharing options...
