craig l Posted January 8, 2007 Share Posted January 8, 2007 hey anyone who can help just got my car back after getting the thor fcd fitted( jspec man tt) by an auto electician, its now idling a bit lower halfway between 0 and 1000rpm. its spluttering away like it gonna cut out its never done that before seems to be driving ok apart from that, anyone any ideas as to what could be causing this, do u think its been fitted wrong. i dont know much about them apart from it stops fuel cut there my knowledge ends lol Quote Link to comment Share on other sites More sharing options...
Steve Posted January 8, 2007 Share Posted January 8, 2007 Could try resetting the ECU, then going for drive to see if that helps. Quote Link to comment Share on other sites More sharing options...
Ric Posted January 8, 2007 Share Posted January 8, 2007 i had this exact problem, Thor must be giving out a bad batch of FCD's take out the FCD and get it replaced, all will be good again Quote Link to comment Share on other sites More sharing options...
craig l Posted January 8, 2007 Author Share Posted January 8, 2007 thanks mate does the ecu need reset anyway after fitting a fcd cos i know thats not been done or do u just wire it up and thats it Quote Link to comment Share on other sites More sharing options...
Steve Posted January 8, 2007 Share Posted January 8, 2007 Always worth a try. If not could be a faulty FCD as mentioned. Quote Link to comment Share on other sites More sharing options...
Guest Pizza-Tosser Posted January 10, 2007 Share Posted January 10, 2007 I seem to remember someone testing a Thor FDC and finding it modulated some nasty square wave onto the map sensor signal. If your auto electrical bloke has a scope get him to test it. Ivor. Quote Link to comment Share on other sites More sharing options...
Jake Posted January 10, 2007 Share Posted January 10, 2007 does the ecu need reset anyway after fitting a fcd cos i know thats not been done Did he not disconnect the battery while fitting the FCD? Quote Link to comment Share on other sites More sharing options...
mr lover Posted January 10, 2007 Share Posted January 10, 2007 i had this exact problem, Thor must be giving out a bad batch of FCD's take out the FCD and get it replaced, all will be good again i had this problem as well thor said they had a batch with wrong chip, i spoke to pete at thor and he replaced it FOC Quote Link to comment Share on other sites More sharing options...
