rpslaughter1982 Posted January 11, 2007 Author Share Posted January 11, 2007 Had the same problem mate tried a few different things but in the end used my PHR oil feed return plate with a new 90 angle adapter use can get them from here http://www.thinkauto.com/ . I got mine from Greg @ Turbofit who was a top man and sorted out a custom one out me. Hope you get it sorted EDIT: See below just found a photo Thanks, I've now ordered the adapter from thinkauto so will soon have the same setup as you[GRIN][/GRIN] Quote Link to comment Share on other sites More sharing options...
fisherjohn Posted January 12, 2007 Share Posted January 12, 2007 i have been running that turbo for last 2 years or more ( L4 SUP ) it made 520 at the rear wheels at thor racing at approx 1.3 bar. My car is j spec with aem and ik 27 plugs also with the aem c2di running wasted spark. I have had a problem for the last year with the gearbox though as it is automatic and am now having thor refit the old ecu and fields harness to run the gearbox only and the aem to run the engine etc. Apart from that my car has run very well also with 3600 uprated torque convertor. Quote Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted January 12, 2007 Author Share Posted January 12, 2007 i have been running that turbo for last 2 years or more ( L4 SUP ) it made 520 at the rear wheels at thor racing at approx 1.3 bar. My car is j spec with aem and ik 27 plugs also with the aem c2di running wasted spark. I have had a problem for the last year with the gearbox though as it is automatic and am now having thor refit the old ecu and fields harness to run the gearbox only and the aem to run the engine etc. Apart from that my car has run very well also with 3600 uprated torque convertor. Thanx for the info, I'll probably be asking you a few questions nearing completion time! Mine's a manual so hopefully I shouldn't run into to too many problems but that power output seems perfect. Did you do the mapping yourself? Quote Link to comment Share on other sites More sharing options...
Wez Posted January 12, 2007 Share Posted January 12, 2007 i have been running that turbo for last 2 years or more ( L4 SUP ) it made 520 at the rear wheels at thor racing at approx 1.3 bar. My car is j spec with aem and ik 27 plugs also with the aem c2di running wasted spark. I have had a problem for the last year with the gearbox though as it is automatic and am now having thor refit the old ecu and fields harness to run the gearbox only and the aem to run the engine etc. Apart from that my car has run very well also with 3600 uprated torque convertor. John have you spoken to Dimitri regarding the AEM and autobox? Is it a standard autobox? Quote Link to comment Share on other sites More sharing options...
fisherjohn Posted January 13, 2007 Share Posted January 13, 2007 Hi Wez, Long time no speak, no i have not but apparently Pete Betts obviously knows that there are issues with aem and an autobox, apparently lot of people have used stock ecu to run the gearbox, my car will hardly pull away at the moment, needless to say after the enormous amount i have spent on this thing it has pixxed me off greatly, it is a standard box btw with 3600 torque convertor, i have not been on here for months actually Quote Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted January 22, 2007 Author Share Posted January 22, 2007 Time for an update: problems with the down pipe. As you can see from one of the pics the screamer pipe hits the PHR downpipe! How stupid, they sell this as a kit and by bolting all the bits together they supply they foul!!![sHOCK][/sHOCK] Not happy. Second problem being the downpipe doesnt match the decat pipe (I knew this was coming though). What I really need to get is a custom down pipe made up. I know some people have done that on the forum so I would really appreciate some advice and suggestions where to get it done, many thanks Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 22, 2007 Share Posted January 22, 2007 Turbofit made my custom downpipe, they would be able to mod your screamer aswell as they have a full time welder/fabricator there at all times but you will need to get the car to them, they have a guy that picks them up on a low loader at a very reasonable price;) 01908 614971 Quote Link to comment Share on other sites More sharing options...
supra matt Posted January 22, 2007 Share Posted January 22, 2007 Time for an update: problems with the down pipe. As you can see from one of the pics the screamer pipe hits the PHR downpipe! How stupid, they sell this as a kit and by bolting all the bits together they supply they foul!!![sHOCK][/sHOCK] Not happy. Second problem being the downpipe doesnt match the decat pipe (I knew this was coming though). What I really need to get is a custom down pipe made up. I know some people have done that on the forum so I would really appreciate some advice and suggestions where to get it done, many thanks Hi mate sorry to see you having trouble ! I think you will find they built it round a uk spec car so you will need to buy a uk spec down pipe it will then mate up right, As for the waste gate look's like you just need to spine it sound so the screamer pipe gose into the bend of the down pipe if that maks sence? Hope this helps Quote Link to comment Share on other sites More sharing options...
Nic Posted January 22, 2007 Share Posted January 22, 2007 Did you not get a mid pipe in the kit? The downpipe is not normally designed to fit the the decat pipe, you will normally also need a mid pipe and a V Band adapter, so it will fit a cat back exhaust (their mid pipe has a v band end to fit the HKS exhaust). The dump pipe should also fit if fitted correctly, might be worth contacting Jarrett at PHR and sending him pics. Quote Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted January 23, 2007 Author Share Posted January 23, 2007 Did you not get a mid pipe in the kit? The downpipe is not normally designed to fit the the decat pipe, you will normally also need a mid pipe and a V Band adapter, so it will fit a cat back exhaust (their mid pipe has a v band end to fit the HKS exhaust). The dump pipe should also fit if fitted correctly, might be worth contacting Jarrett at PHR and sending him pics. Thanks for the replies. The kit did not come with a mid pipe as allegedly it was designed to mate up with the stadard exhaust. I was aware that it wasn't going to fit exacly because of the usa / jap different exhausts (although I thought it would just be a different flange). On the wastegate front it doesn't rotate and the way its on is the only way it fits, I'll give PHR an e-mail to let them know. I think my best plan of action is to get a new down pipe made up with the mounts for the various sensors Quote Link to comment Share on other sites More sharing options...
Wez Posted January 23, 2007 Share Posted January 23, 2007 I got mine done at Hayward and Scott and very please with the results. They will need the car and when they did mine they also made brackets to hold it all together. http://www.haywardandscott.co.uk/ Quote Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted January 25, 2007 Author Share Posted January 25, 2007 Can anyone tell me the part number for this coolant hose? Answered my own question, M T87209-14810 = £52.42+vat!!!!!!!!!!! I'll get some other hosing for the time being thanks Toyota Quote Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted January 26, 2007 Author Share Posted January 26, 2007 I want a 3 inch exhaust flexi pipe (or bellow) like the one Homer had welded to his exhaust, does any one know where to get one? http://img170.imageshack.us/my.php?image=forum91yf5.jpg Quote Link to comment Share on other sites More sharing options...
supra matt Posted January 26, 2007 Share Posted January 26, 2007 try demon tweeks mate the motor sport section Quote Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted January 28, 2007 Author Share Posted January 28, 2007 try demon tweeks mate the motor sport section Cheers, they've got some good stuff on there and the exhaust piping seems fairly cheap. I found the piece I was after though on http://www.dynoflow.co.uk. May help if anyone is looking for similar bits:) Quote Link to comment Share on other sites More sharing options...
Kranz Posted January 28, 2007 Share Posted January 28, 2007 Not got it finished yet Rich??? By the time yours is back on the road mine'll be off the road having its BPU++. Quote Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted January 30, 2007 Author Share Posted January 30, 2007 Not got it finished yet Rich??? By the time yours is back on the road mine'll be off the road having its BPU++. You gotta cut me some slack mate, since I started this project I've been distracted by getting married, going to china for a couple of weeks and getting the misses pregnant. I hope it's finished before the little'en arrives or it may never get finished!!!!!!!! Quote Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted January 30, 2007 Author Share Posted January 30, 2007 Just thought I'd post a summary of the tricky bits so far: PHR Street Turbo Kit ordered. This kit comes with a turbo elbow that bolts that bolts to the exhaust side of the turbo with a gasket. The turbo elbow is designed to match up with a US spec exhaust so will not fit the jap ones. I have a jap spec decat pipe which I have cut the flange off of. This will soon be welded to teh turbo elbow with a steel flexi joiner to get round the problem. I also found that the turbo elbow flange hit the screamer pipe when fitted. Not a big problem for me as I have cut the pipe anyway but if someone wishes to mate it to a US spec exhaust they may have trouble. Another problem is the oil return. The turbo sits considerably lower than other kits I have seen whcih makes it difficult to get the feed fitted round the power steering mechanisms. In order to fit it to a RHD car it will have to be modified. I have modified this by buying a male/male 90 degree which bolts to the block and shortening the oil return pipe itself. The kit comes with 'drop down' style intercooler piping which did not match up with my intercooler. I have cut this pipe around and rotated the turb so that it routes to where the original piping went. Quote Link to comment Share on other sites More sharing options...
Kranz Posted February 7, 2007 Share Posted February 7, 2007 I've been distracted by getting married Where was my invite then? Congrats BTW..... And you're right. you HAVE to finish it before the nipper comes along, or else wait about 18 years If you need a hand/tools/stuff you know where I am mate! Quote Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted February 10, 2007 Author Share Posted February 10, 2007 urgent - (nearly to the point of starting) Can anyone tell me what fuel pressure i should be running with the single - 650cc injectors, stock rail, fuel pulsation bypass, afpr - many thanks Quote Link to comment Share on other sites More sharing options...
Jake Posted February 10, 2007 Share Posted February 10, 2007 Stock fuel pressure should be fine. What's AFPR mean? What are you using to trim the injectors? Edit, Nevermind, I searched the thread Quote Link to comment Share on other sites More sharing options...
Homer Posted February 10, 2007 Share Posted February 10, 2007 33-38 psi will be fine. Ian recommended 38psi for my setup which is essentially the same. Quote Link to comment Share on other sites More sharing options...
supra matt Posted February 10, 2007 Share Posted February 10, 2007 and are you not ment to set the fuel pressure with the vacum off as well? Quote Link to comment Share on other sites More sharing options...
Wez Posted February 10, 2007 Share Posted February 10, 2007 and are you not ment to set the fuel pressure with the vacum off as well? Correct. Quote Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted February 11, 2007 Author Share Posted February 11, 2007 Thanks for your help peeps. Actually turned it over for the first time since september yesterday with no major drama! I've taken some pics and a short vid which I'll post as soon I get my camera working. Quote Link to comment Share on other sites More sharing options...
