Nick Posted August 28, 2001 Share Posted August 28, 2001 Does anyone know where I can get a Blitz FCD for the MKIV VVT-i? Racelogic quote a lead time of 6 weeks so obviously I'd rather buy one elsewhere. I'm on my second TRL VFCC but this hasn't cured the problem. I thought the first unit was faulty or that I had a duff earth but it seems that the VVT-i handles fuel cut differently. Racelogic confirmed this today, they tell me Blitz make a unit specifically for the VVT-i. SVS can supply a Greddy unit within ten days but they don't quote a VVT-i specific unit and I don't want to take the chance of it not working. Thanks. Quote Link to comment Share on other sites More sharing options...
Ring Master Posted August 28, 2001 Share Posted August 28, 2001 If you are desperate you could use the HKS fuel cut defencer, which is in stock £95+v Other option is a Blitz ECU, not as expensive as you might think and that completely does away fuel cut £1301+vat-big discount Or an HKS F-con 5 Quote Link to comment Share on other sites More sharing options...
Ring Master Posted August 28, 2001 Share Posted August 28, 2001 Of course, you dont want to wait ! Chances of any supplier stocking a Blitz VVti FCD are slim to zero. Looks like you may have to wait the 6-8 weeks mate. Cant you ask Peter Betts to work out what needs to be done to his FCD to make it work on your vvti ? Quote Link to comment Share on other sites More sharing options...
Nick Posted August 28, 2001 Author Share Posted August 28, 2001 I've got an F-CON5, GCC and harness sitting on the shelf if you know anyone that wants them. Taking the AVC-R out tomorrow as well. Pete and I have discussed my fuel cut problem and we're both baffled as to why it doesn't work. The VVT-i ECU must be checking something else as well because the VFCC doesn't work on any setting. I don't think the HKS FCD will work, are you able to ask HKS Europe?? I'm willing to try one providing I can have my money back if it doesn't... Cheers, Nick Quote Link to comment Share on other sites More sharing options...
Ring Master Posted August 28, 2001 Share Posted August 28, 2001 Hi Nick, Im sure I can find a home for your spare parts for a fair price , contact me direct on [email protected] (especially the AVCR) Im not convinced the HKS FCD will work either, I will try and speak to HKS asap, I will also speak to my man in the US who knows everything possible about tuning supras. Sorry to hear about your problems, must be very frustrating. 8( Quote Link to comment Share on other sites More sharing options...
Phil Posted August 29, 2001 Share Posted August 29, 2001 I had a similar problem of not going over 15 psi even with Pete's FCD fitted. After much head scratching and a visit to Pete it turned out to be the Spark Plugs breaking down, they would get to 15psi but then misfire and go no higher. Changed for a set of NGK R plugs (Thanks Justin!) and went straight round to 19psi! Do you know what plugs you have? Quote Link to comment Share on other sites More sharing options...
Nick Posted August 29, 2001 Author Share Posted August 29, 2001 We thought it could be the plugs as well so they were changed, good job too as they were knackered. ChrisW supplied a set of NGK Racing (R7234-8) but I still hit fuel cut at 1.2bar. The Blitz ECU is an option but a rather expensive one. I've spoken to Racelogic about the ECU before thinking I could use it with larger turbos, injectors etc as they say it can be re-mapped. It can't handle major mods, only minor ones. If I bought it the car would only be able to run BPU. Quote Link to comment Share on other sites More sharing options...
Guest Ash Posted August 29, 2001 Share Posted August 29, 2001 I keep saying this so maybe ADMIN can put it up on the MKIV home page somewhere.............. Any MKIV running higher than stock boost should run 1-grade colder plugs GAPPED TO 0.85mm. Otherwise you run the risk of encountering high-boost misfire. It doesn't happen with all cars under all circumstances. But it's happened to me EVEN WITH HKS PLUGS FITTED. It also happened to Justin. In my case it was only when the HKS plugs were gapped to 0.85mm that the misfire went away. In Justin's case he gapped the plugs to 0.85mm following my advice upon fitting. His misfire went away also. As regards plugs, if you are feeling quite flush and want to buy Nippon Denso plugs with pretty little HKS logos on them they are available for about £15 each. If you are not so loaded, you can get basically the same thing from NGK for around £15 a set of six. Yours, J Quote Link to comment Share on other sites More sharing options...
Nick Posted August 29, 2001 Author Share Posted August 29, 2001 I haven't checked that the gap is correct, I'll do that today before I do anything else. I do know that they're the correct grade though. Justin, your sales Email has just returned my mail with a fatal error.... Quote Link to comment Share on other sites More sharing options...
Guest Ash Posted August 29, 2001 Share Posted August 29, 2001 Sounds like the HKS hitman just made his kill. :biggrin: Yours, J Quote Link to comment Share on other sites More sharing options...
Branners Posted August 29, 2001 Share Posted August 29, 2001 I have no idea what happened to the sales mail account, but its back to normal now.... JB Quote Link to comment Share on other sites More sharing options...
Ring Master Posted August 29, 2001 Share Posted August 29, 2001 Nick, HKS Japan list a VVti specific FCD !!!!! Should take a lot less than 6 weeks ! Quote Link to comment Share on other sites More sharing options...
Nick Posted August 29, 2001 Author Share Posted August 29, 2001 Brillant, how much can you get me one for and when??? Quote Link to comment Share on other sites More sharing options...
