Darren Posted January 7, 2007 Share Posted January 7, 2007 UK rear calipers - How different are they from J-spec? Are they worth changing to? I've just fitted UK fronts. Link to comment Share on other sites More sharing options...
ajazyasin Posted January 7, 2007 Share Posted January 7, 2007 they are twin piston. J-spec are single floating i think. Link to comment Share on other sites More sharing options...
paul mac Posted January 7, 2007 Share Posted January 7, 2007 you will also need new disks as well Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 8, 2007 Share Posted January 8, 2007 And to cut back the dirt shield. However, you NEED to change rear discs and calipers for a properly balanced UK conversion. Link to comment Share on other sites More sharing options...
Ian C Posted January 8, 2007 Share Posted January 8, 2007 Not that the rears do much. I've got CW fast road pads in and the rears look like they are going to just about outlast two sets of fronts. I wish I could get some bias back to the rear set but the only person I know who could do that deletes the bloody ABS in doing so -Ian Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 8, 2007 Share Posted January 8, 2007 You could do what I did and make a proper twin master cylinder bias brake set uo. You could retain the ABS like this. Not sure if there would be room without deleting the servo, as I did on my Skyline ftp://ftp.chriswilson.tv/Skyline_stuff/bias_brakes Link to comment Share on other sites More sharing options...
simonas Posted January 8, 2007 Share Posted January 8, 2007 wrong thread.. oops Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 8, 2007 Share Posted January 8, 2007 No just back off the h/brake shoes before removing the rear discs, and reset the adjusters after you fit the new discs. Very straightforward IMO. Link to comment Share on other sites More sharing options...
Ian C Posted January 8, 2007 Share Posted January 8, 2007 You could do what I did and make a proper twin master cylinder bias brake set uo. You could retain the ABS like this. Not sure if there would be room without deleting the servo, as I did on my Skyline ftp://ftp.chriswilson.tv/Skyline_stuff/bias_brakes For some reason I can't get into that link, but if it's the same thing I saw a while back and asked you about, back then you said it deletes the ABS -Ian Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 8, 2007 Share Posted January 8, 2007 It need not abandon the ABS, my car was never fitted with ABS from new, but there's no reason dual master cylindrers won't work with ABS, AFAIK. Link to comment Share on other sites More sharing options...
Darren Posted January 8, 2007 Author Share Posted January 8, 2007 you will also need new disks as well So the disks are bigger too? Link to comment Share on other sites More sharing options...
paul mac Posted January 8, 2007 Share Posted January 8, 2007 So the disks are bigger too? yes i think the j specs are 280mm and the UK are 320mm, something like that but defo bigger Link to comment Share on other sites More sharing options...
Darren Posted January 8, 2007 Author Share Posted January 8, 2007 yes i think the j specs are 280mm and the UK are 320mm, something like that but defo bigger What the rears are 320 too? Link to comment Share on other sites More sharing options...
Nic Posted January 9, 2007 Share Posted January 9, 2007 What the rears are 320 too? The front discs are 323mm diameter, the rears are 324mm. If you want prices for rear set up Darren let me know. Link to comment Share on other sites More sharing options...
Darren Posted January 9, 2007 Author Share Posted January 9, 2007 The front discs are 323mm diameter, the rears are 324mm. If you want prices for rear set up Darren let me know. Thanks Nic, I'm interested in a price but not in a mad rush! Link to comment Share on other sites More sharing options...
Nic Posted January 9, 2007 Share Posted January 9, 2007 Thanks Nic, I'm interested in a price but not in a mad rush! Hi Darren For a 2 pot pair of rear calipers and fitting kit, the price would be £375 including postage. cheers Link to comment Share on other sites More sharing options...
