Senspr / Idle Cost
dirtydan
Hi,
How much would you say a reasonable garage would charge to supply and fit Idle Valve & o2 Sensor? (Uk Spec)
Cheers Dan:search:
Hi Dan
The O2 sensor and idle control valve will both be very expensive to buy new from your local Toyota dealer.
I should be able to supply quite a bit cheaper, but order time would be around 4 weeks. If you would like details please let me know.
cheers
Idle control valve is circa £280 !
O2 sensor is around £90
You could fit both yourself fairly easily, have a look in the tech articles for a few pictures of their locations.
Also look at a guide titled "blitz twin turbo installation" as part way through that it shows you how to remove the IAC valve
I have a J-spec idle valve sat here waiting for a new home, I believe they are the same part, if you're interested, you may want to start a thread to confirm it is.
Yes they are the same part number 22270-46060
