2JZGTE single turbo engine with a lot of extras
dk_supra
I just finished last night another nice engine package.
2JZGTE block 35,000klm (180psi on every cylinder compression) perfect engine
Built head 5 angle job, Aftermarket springs, new valve seals, and HKS 264s on it, perfectly shimmed of course
Stock intake manifold with 850cc side feeds, dual feed rail.
PT67 turbocharger with approx. 7534klm on it, no play, no smoke, HKS 50mm wastegate with 1 bar spring (additional 1.4 bar spring)
XS manifold modified to my likes, flanges, skimming etc, it looks and performs flawless.
Oil lines etc, air lines for wastegate, and fuel lines all with AN connectors.New cam belt, new iridium plugs, coil packs included.
Boost logic Crank pulley.
ARP studs on the head
Harness Included from a UK Spec car
AC Compressor
Power steering Pump
Alternator
New V belt.
We run this engine on a Mercedes for 7534klm, customer wants to go for something a lot more aggressive, so we are building another engine for him, we are selling it because it a shame to change the internals of a perfect stock block. The engine doesn't consume any oil, never smokes and really goes very well.
We have run this with 550cc injectors at 1.1 bar at 97% duty cycle to keep the AFR to 11.5. Then we installed the 264 cams and the 850cc, and run it at 1.5 bars and we were running between 79-81 % duty cycle for the 11.5 AFRs. That's all of course on 100 octane pump gas.
It was of course running on an AEM ecu with HKS DLI.
This is a long block capable of easily 680rwhp at 1.5 bars
Price of this is 10,000 pounds and it includes the tuning of your AEM when you install it in your vehicle. Meaning my plane ticket, accomodation, and tuning of the car.
Engine can come with either mid sump for Supra, or front sump for any other vehicle.
If don't need the tuning part then price is down to 9000 pounds.
Cheers
Dimitri
Pretty easy, the work to install is going to be around 2k pounds, and whatever it costs you for the aem, dli and aem sensors, minor details might be needed, but your budget should be around that area. Vehicle should be driven or shipped to Greece. Cost of shipping the vehicle is around 500 pounds, and driving 1000 pounds.
Sorry i forgot the cost of the 2 walbros, and the extra fuel line. But this is really very small maybe about 400-500 pounds at the most.
Transmission wise you can keep your stock transmission if manual, or i can install a stock auto for free. Getrag 6 speed is of course additional but very feasible.
