JamieP Posted January 4, 2007 Share Posted January 4, 2007 A good friend of mine has just done a full rebuild on his skyline gtr and has very high oil pressure (8bar with his foot down) he put a new pump in when rebuilding, it runs and drive fine, no sign of blowing seals, possible just damaged sender? Any ideas to the cause? thanks jamie:) Quote Link to comment Share on other sites More sharing options...
absz Posted January 4, 2007 Share Posted January 4, 2007 1/ too thick of oil 2/ sticking oil pressure relief valve just of the top of my head for starters:) Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 5, 2007 Author Share Posted January 5, 2007 Ok thanks abs ill pass them ideas on, any others? Quote Link to comment Share on other sites More sharing options...
mattanna Posted January 5, 2007 Share Posted January 5, 2007 Yes i am no technical wizard by any means, but i suppose if it is running fine it could be an oil pressure sensor fault, i am sure you can get some sort of diag to actually check that the oil pressure is really high or not?? GTR forums may know Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 5, 2007 Author Share Posted January 5, 2007 Yea he is hoping its just the gauge, gonna try to swap with another tomorrow to find out. Its like a rev counter, flys up and down with the revs:D Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 5, 2007 Share Posted January 5, 2007 If its any consolation my Supra runs about the same a higher RPM never been a problem, "wheres the fingers crossed smiley" Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 5, 2007 Author Share Posted January 5, 2007 If its any consolation my Supra runs about the same a higher RPM never been a problem, "wheres the fingers crossed smiley" Really? Didnt you have a problem with a blown front main seal? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 5, 2007 Share Posted January 5, 2007 Yes but i'm pretty sure its not related, i suspect it was just old and brittle, done another 2.5K including RR day and some spirited driving since:) Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 5, 2007 Author Share Posted January 5, 2007 Ok thats good news, ill pass that on.. thanks:) Quote Link to comment Share on other sites More sharing options...
ECK Posted January 5, 2007 Share Posted January 5, 2007 Yea he is hoping its just the gauge, gonna try to swap with another tomorrow to find out. Its like a rev counter, flys up and down with the revs:D sounds more like a resistance fault with the combo metre! try to manualy check the oil pressure with a guage but 8 bar sounds alot and there would defo be leaks at that pressure check all earths are clean just a thot! Quote Link to comment Share on other sites More sharing options...
