Lebsteif Posted January 4, 2007 Share Posted January 4, 2007 I have bought a HKS SLD TypeI, there instructions included but no english manual. I used the search but in none of the topics i have found is a proper manual. Can somebody help me please Quote Link to comment Share on other sites More sharing options...
Lebsteif Posted January 4, 2007 Author Share Posted January 4, 2007 Nevermind, i;m just so stupid (sometimes) http://mkivsupra.net/vbb/showthread.php?t=69446 WTF, i have a 5 wire SLD and not a 4 wire version that has been described. Is there a difference between them? (got an extra bleu wire) Quote Link to comment Share on other sites More sharing options...
Nic Posted January 4, 2007 Share Posted January 4, 2007 For a 96 manual NA you need the SLD Type I part number 4502-RA002 There are a number of different versions of the HKS SLD Quote Link to comment Share on other sites More sharing options...
Lebsteif Posted January 4, 2007 Author Share Posted January 4, 2007 Good to know, thanks Nic. I checked directly the backside of the box and it says 4502-RA002 as well. Strange that i have 5 wires Quote Link to comment Share on other sites More sharing options...
Lebsteif Posted January 4, 2007 Author Share Posted January 4, 2007 http://www.archanox.demon.nl/DSC00999.JPG http://www.archanox.demon.nl/DSC01000.JPG http://www.archanox.demon.nl/DSC01001.JPG http://www.archanox.demon.nl/DSC01002.JPG Quote Link to comment Share on other sites More sharing options...
Lebsteif Posted January 5, 2007 Author Share Posted January 5, 2007 bump Quote Link to comment Share on other sites More sharing options...
Suup Posted January 5, 2007 Share Posted January 5, 2007 Hmm i'm also curious..... It would be fine if anyone can help us out, i've got this verry same question in a few months i think. Free bumb Quote Link to comment Share on other sites More sharing options...
bondango Posted January 5, 2007 Share Posted January 5, 2007 I'm waiting on a type t6 SLD coming in for an Aristo 2jzgte as they have a problem with the TRAC system, i know one of the wires on it is destined for the Trac ECU. Maybe the type 1 had that option? if i find out any details il post them up. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 5, 2007 Share Posted January 5, 2007 It is the light blue wire that is the odd one, the others should be connected like this. Yellow - Speed sensor wire to ECU White - Speed Sensor wire to loom Black - Earth Red - 12V ignition feed Perhaps try connecting these 4 wires first and then test to see if works. Quote Link to comment Share on other sites More sharing options...
Lebsteif Posted January 5, 2007 Author Share Posted January 5, 2007 I'm waiting on a type t6 SLD coming in for an Aristo 2jzgte as they have a problem with the TRAC system, i know one of the wires on it is destined for the Trac ECU. Maybe the type 1 had that option? if i find out any details il post them up. Ah that could be a reason! It is the light blue wire that is the odd one, the others should be connected like this. Yellow - Speed sensor wire to ECU White - Speed Sensor wire to loom Black - Earth Red - 12V ignition feed Perhaps try connecting these 4 wires first and then test to see if works. Thanks Nic, i;m going to give it a go. we will see what happens Quote Link to comment Share on other sites More sharing options...
Suup Posted January 5, 2007 Share Posted January 5, 2007 Maby the blue one is made for a switch function. So you can switch the SLD on and off by using an external button or something like that??? Just like the antenna from a radio. Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted January 5, 2007 Share Posted January 5, 2007 Dont think I used the blue one at all. Quote Link to comment Share on other sites More sharing options...
Guest biglipzit Posted January 6, 2007 Share Posted January 6, 2007 So what about the wiring for the HKS SLD Type 2? Just got one and it has 12 wires. Don't have a clue as to what each one does. Any help? I have searched the forums and not one person has posted any wiring information for the HKS SLD type 2. If i only use the 4 wires will it work? or are things different on an automatic mkiv? Quote Link to comment Share on other sites More sharing options...
bondango Posted January 6, 2007 Share Posted January 6, 2007 http://www.hks-power.co.jp/products/electronics/speed/sld_data.html From the looks of it, type II and T6 are for autos. Dunno if any of the HKS traders would be willing to scan the info for the european supplied parts. Quote Link to comment Share on other sites More sharing options...
Guest Akitoshi Posted September 15, 2009 Share Posted September 15, 2009 http://www.supra-club.ru/board/index.php?showtopic=2766 Quote Link to comment Share on other sites More sharing options...
