tDR Posted November 2, 2009 Share Posted November 2, 2009 Right I'm currently ordering parts from whifbitz for a full BPU. I've got a 96 J-spec RZ-S, I already have a Blitz Nur spec cat back system fitted, so I'm after: HKS FCD Question is what grade plugs do I go for? Grade 7's. Check out the spark plug FAQ for well documented info on the subject. I'd always go with a GReddy BCC (another name for an FCD) over the HKS FCD because of the method it uses to fool the stock ECU on the airflow signal. Cheers, Brian. Link to comment Share on other sites More sharing options...
deathmonkey Posted February 5, 2010 Share Posted February 5, 2010 Massive apologies if this has been answered either on this thread or elsewhere, I've searched solid, I promise ! Anyway, as I'm hoping to go BPU by the summer, I was just wondering what type of fuel I should be aiming to use? Does it not change from what I've always done - use the best at whatever station I'm at, or should I really be looking to use v-power for example, when I do eventually go BPU. Thanks guys, again apologies if already answered. Link to comment Share on other sites More sharing options...
Homer Posted February 5, 2010 Author Share Posted February 5, 2010 Simply use the higest octane fuel available to you. Shell v-power, BP Ultimate, etc. As always, ensure you have an AFR (worry gauge) to keep an eye on the levels and if it gets beyond limits back off. I wouldn't recommend it though if only low octane is avaiable, unless the car has an aftermarket ECU & map at higher boost pressures (1.1 and above) it's *needed* to use high octane fuel. Peak power is not the issue, it's the switch-over point that causes det. Link to comment Share on other sites More sharing options...
deathmonkey Posted February 5, 2010 Share Posted February 5, 2010 Simply use the higest octane fuel available to you. Shell v-power, BP Ultimate, etc. As always, ensure you have an AFR (worry gauge) to keep an eye on the levels and if it gets beyond limits back off. I wouldn't recommend it though if only low octane is avaiable, unless the car has an aftermarket ECU & map at higher boost pressures (1.1 and above) it's *needed* to use high octane fuel. Peak power is not the issue, it's the switch-over point that causes det. Thanks for the reply Homer, good to know . Link to comment Share on other sites More sharing options...
BABZ988 Posted March 11, 2010 Share Posted March 11, 2010 i think: if i buy a tanabe full decat system (usually a 4"); i'll need a restrictor ring ! but if i buy a 2.5 decat system from whifbitz ; will still need a ring? looking for BPU at the moment! Link to comment Share on other sites More sharing options...
Homer Posted March 12, 2010 Author Share Posted March 12, 2010 If it'a a jspec then yes, you will need the restrictor ring and the other mods before decatting, regardless of the exhuast diameter. Link to comment Share on other sites More sharing options...
Pudsey Posted May 14, 2010 Share Posted May 14, 2010 Can someone answer me this, as there seems to be some differences of opinion. I am BPU'ing my 1998 VTT-i Twin Turbo. I need to know if I need a Fuel Cut Defender or not. If I don't fit it and run the car without it will it get damaged? Any advice would be appreciated and is rather urgent due to attending Japfest tomorrow. Link to comment Share on other sites More sharing options...
Thorin Posted May 14, 2010 Share Posted May 14, 2010 You need one, otherwise you'll hit fuel cut >1.0bar Link to comment Share on other sites More sharing options...
Shane Posted May 18, 2010 Share Posted May 18, 2010 Just about to go BPU and I have a couple of questions both relating to the ristrictor ring. With the restrictor ring in with a hole of say 2 inches, is there any real point or advantage with a 3" exhaust, surely the ring becomes the most restrictive point and any advantage of a big bore exhaust after the ring is lost? If I use 3" decat pipes and then have the ring between the second decat and the exhaust, surely when the engine is suddenley revved hard, until the pressure is built up between the turbos and the restrictor ring it is possible to overboost? I know this is all proven territory and don't question it works as of course it does but as I was looking at the 3" decat pipes I bought for mine these questions just sprang to mind. Link to comment Share on other sites More sharing options...
supra-ireland Posted June 29, 2010 Share Posted June 29, 2010 I've a question about my BPU setup. I've got an Apexi S-AFC, it came with the car uninstalled. I'm happy to install it myself but having read through the foum some people suggest that there's no point fitting one with a BPU setup. Can the S-AFC improve things or should I just forget about it? I've got stock turbos and was hoping to usually limit boost to 1.0 bar and occasionally go up to 1.2 bar. Link to comment Share on other sites More sharing options...
tDR Posted June 29, 2010 Share Posted June 29, 2010 Sell it and do things properly if you want to get into tweaking maps IMO. Link to comment Share on other sites More sharing options...
supra-ireland Posted June 29, 2010 Share Posted June 29, 2010 Sell it and do things properly if you want to get into tweaking maps IMO. Ok, thanks. So at a BPU level is there much point with aftermarket ECUs and the like or are you as well to stay with stock? Link to comment Share on other sites More sharing options...
tDR Posted June 29, 2010 Share Posted June 29, 2010 I'd say there's definitely gains to be had but the ECU or piggyback needs to have decent resolution mapping wise to really get the most out of the sequential setup to optimise the fuelling and timing across the rev range. Link to comment Share on other sites More sharing options...
supra-ireland Posted June 29, 2010 Share Posted June 29, 2010 I'd say there's definitely gains to be had but the ECU or piggyback needs to have decent resolution mapping wise to really get the most out of the sequential setup to optimise the fuelling and timing across the rev range. Is there anything you could recommend? I want to keep costs down but at the same time I'm willing to spend enough to get something proper. Thanks for the advice. Link to comment Share on other sites More sharing options...
Peter P Posted June 29, 2010 Share Posted June 29, 2010 Is there anything you could recommend? I want to keep costs down but at the same time I'm willing to spend enough to get something proper. Thanks for the advice. Would recommend looking at one of the SYVEC ECU's that Ryan does as these seem very comprehensive and would be future proofed if you went single at a later date. The Whifbitz Time Attack cars both run this ECU to good effect and it also has goodies such as traction control and boost control involved. Have a look under 2 bar tuning as a trader and see what you think. There are other options but Ryan sets these up perfectly and the piece of mind having UK support both with the manufacturer and tuner appeals to me. Will be what I go for when I get my next one! Just my opinion by the way. Pete Link to comment Share on other sites More sharing options...
tDR Posted June 30, 2010 Share Posted June 30, 2010 Syvecs is an excellent choice if you're going standalone, also with good recent write-ups is the AEM piggyback which is probably more appropriate if you're auto. RyanG on this forum likes to map both of those choices. Other piggybacks I like are the GReddy emanage ultimate and the MAP-ECU2. Link to comment Share on other sites More sharing options...
supra-ireland Posted June 30, 2010 Share Posted June 30, 2010 Cheers Peter. TDR, you got it just before me. I've just read all of Ryan's threads on the Solaris and the AEM FIC. I agree with you, I think the AEM is much more suitable for me. My aim is for a good, reliable BPU setup giving me around 400BHP. I may go for a single setup in the future but it's a long way off. Link to comment Share on other sites More sharing options...
PDowdy Posted August 2, 2010 Share Posted August 2, 2010 sorry if this is an obvious question but I wasn't totally sure after reading through this. Does a jspec require a restrictor ring if you're fitting an electronic boost controller ?? Is it ok to run both ?? (I'm guessing yes but just want to double check) Link to comment Share on other sites More sharing options...
Mcgoo Posted August 2, 2010 Share Posted August 2, 2010 sorry if this is an obvious question but I wasn't totally sure after reading through this. Does a jspec require a restrictor ring if you're fitting an electronic boost controller ?? Is it ok to run both ?? (I'm guessing yes but just want to double check) It's 'best' to run both really. Most people will fit a 1.0 or 1.1 bar restrictor ring and then use the EBC to raise it to 1.2 bar when required. Without a restrictor ring the boost can go through the roof causing your turbos to pop. Link to comment Share on other sites More sharing options...
TonytotheB Posted September 20, 2010 Share Posted September 20, 2010 Very simple to understand. Thanks Homer. Link to comment Share on other sites More sharing options...
SupraDan24 Posted November 7, 2010 Share Posted November 7, 2010 Do either the Iridiums on NGK's need to be gapped? I remember reading it on a thread somewhere a while back but i cant find it again. I'm going to be ordering some next week so i'll order which ever ones dont need gapping. Link to comment Share on other sites More sharing options...
Jake Posted November 7, 2010 Share Posted November 7, 2010 Iridium plugs mustn't be re-gapped. Link to comment Share on other sites More sharing options...
damadom Posted March 24, 2011 Share Posted March 24, 2011 can this work on the n/a? Link to comment Share on other sites More sharing options...
Gaz6002 Posted March 24, 2011 Share Posted March 24, 2011 can this work on the n/a? You can decat the NA, but it's not known as BPU as you'll rarely see any 'upgrade'. You certainly won't see anywhere close to 400bhp on an NA. Link to comment Share on other sites More sharing options...
Clancy2k Posted April 29, 2011 Share Posted April 29, 2011 I'm getting an RZ Twin-Turbo next week, i would just like to know how much this BPU costs parts + labour? I'm hoping it's £1000 or less, thanks. Link to comment Share on other sites More sharing options...
