Jake Posted January 26, 2007 Share Posted January 26, 2007 When's this being fitted? Link to comment Share on other sites More sharing options...
wkdtime Posted January 26, 2007 Share Posted January 26, 2007 Jake, it's booked for a rolling road session end of March. So Inshallah (God willing) it will be all done by then:) Link to comment Share on other sites More sharing options...
Jake Posted January 26, 2007 Share Posted January 26, 2007 Oh quite a while to go yet then. I thought Michel was originally talking about doing it this month. Anyway good luck mate. You're gonna love it. Link to comment Share on other sites More sharing options...
wkdtime Posted January 26, 2007 Share Posted January 26, 2007 Oh quite a while to go yet then. I thought Michel was originally talking about doing it this month. Anyway good luck mate. You're gonna love it. He's going to take the car in end of Feb/start of March. Link to comment Share on other sites More sharing options...
wkdtime Posted February 16, 2007 Share Posted February 16, 2007 Update! Going over to Michel's for the single install tomorrow morning....Almost 300 miles to get there, well it's a good excuse to stretch the Supe's legs! Look out for me on the M1:) Link to comment Share on other sites More sharing options...
merckx Posted February 16, 2007 Share Posted February 16, 2007 I've been looking foward to this install being documented! Don't forget to take plenty of nice pics, some of yourself and Michel would be good too. Link to comment Share on other sites More sharing options...
stupra Posted February 16, 2007 Share Posted February 16, 2007 Good luck guy's, hope it all goes smoothly. . I'm no expert, but wouldn't 650 injectors be better than 880's on a t67 though ? Link to comment Share on other sites More sharing options...
wkdtime Posted February 16, 2007 Share Posted February 16, 2007 Good luck guy's, hope it all goes smoothly. . I'm no expert, but wouldn't 650 injectors be better than 880's on a t67 though ? 650's at 1.4Bar in top gear......you'd be pretty close to maxing out the duty cycle of the injectors. 720's would be an ideal choice, but im going for future proofing incase i want more power:) Link to comment Share on other sites More sharing options...
Homer Posted February 16, 2007 Share Posted February 16, 2007 Good luck guy's, hope it all goes smoothly. . I'm no expert, but wouldn't 650 injectors be better than 880's on a t67 though ? Just to echo what has been said, 650's are not adequate for a T67 if you want to run more than 1.2 bar. Here's some info Ian C sent me: My 720's at 38psi static run around 85% to 90% duty at the top end of the rev range and 1.4bar boost. 650's are fine for a T61 at 1.4bar, maybe 1.6 if you crank up the fuel pressure, but you'd see 98% to 100% duty at 1.4bar on a 67, leaving absolutely no headroom for the boost creeping up a bit or running richer in higher gears for intercooler effects etc etc so frankly I wouldn't map that high, maybe 1.2bar maximum. BTW, good luck with the project Adnan, will be interested to hear your impressions after its done. Link to comment Share on other sites More sharing options...
stupra Posted February 17, 2007 Share Posted February 17, 2007 Just to echo what has been said, 650's are not adequate for a T67 if you want to run more than 1.2 bar. QUOTE] Cheers for that Homer . What made me think 650's would be ok, was hearing an owner of a t67 saying he wished he'd stayed with the 650's over the larger injectors he has in the car now, something about the car running better, and the bigger injectors being overkill. Link to comment Share on other sites More sharing options...
Homer Posted February 17, 2007 Share Posted February 17, 2007 What made me think 650's would be ok, was hearing an owner of a t67 saying he wished he'd stayed with the 650's over the larger injectors he has in the car now, something about the car running better, and the bigger injectors being overkill. It wasn't mapped properly then, or had an fueling computer not up to the job (eg an SAFC wouldn't run properly with huge injectors). Link to comment Share on other sites More sharing options...
stupra Posted February 17, 2007 Share Posted February 17, 2007 It wasn't mapped properly then, or had an fueling computer not up to the job (eg an SAFC wouldn't run properly with huge injectors). I wouldn't know mate to be honest, maybe he went for bigger injector's for the reason's yourself and wkdtime have mentioned. His car is mapped beyond 1.2 bar. Link to comment Share on other sites More sharing options...
michel lane Posted February 24, 2007 Author Share Posted February 24, 2007 Well Adanan (wkdtime) dropped his car of for me to start the install. The first thing we had to sort out was the clutch , here are some pics of the ACT PRESSURE PLATE/ BRONZE 6 PUCK PLATE and FERNANDIZ LIGHTENED FLYWHEEL. I will be taking the engine out to do this install because it will take less time. Various problems i have encountered so far is the DP/MP is 4 inch's Adanan exhaust is just short of 3 inch and has a 2 bolt design , i have a 4 inch vband to 2 bolt adaptor to do the job. I think iam going to change the exhaust setup to a 3.5 inch system to the back box..but thats later. Link to comment Share on other sites More sharing options...
Supe Posted February 24, 2007 Share Posted February 24, 2007 Link to comment Share on other sites More sharing options...
colsoop Posted February 24, 2007 Share Posted February 24, 2007 Subscribing Link to comment Share on other sites More sharing options...
michel lane Posted March 6, 2007 Author Share Posted March 6, 2007 Well engine came out, this was due to some small issues with the car - leaking power steering pump / broken engine mount. it makes the job easyer and we can sort out any other issues aswell. We inspected the timing belt and it was loose, fan belt very worn . The power steering pump had a leaky gasket so we retified it with a new gasket kit. The engine was held in place with one mount , the other had was not bolted to the car, because the main hanger was broken . pictures of the engine on the floor. The clutch as been installed. Next will be the manifold, wastegate, dp, mp, turbo. Link to comment Share on other sites More sharing options...
michel lane Posted March 25, 2007 Author Share Posted March 25, 2007 Well its a week before the tuning and so far we have sorted out : 1:full fuel system install 2:various corroded pipes 3:exhaust issues The Fuel system we have used is a one deviced by myself, it carries 2 walbro pumps , running a dual line towards the front of the car , then both lines go into a -10n aeromotive fuel filter , then a line from the filter (-10n) ,which then goes to the rail -10n to -6n, the FPR (aeromotive unit) then takes the 2nd input of the fuel rail -6n. The standard return line is used , but converted to a -6n in the engine bay. The location is situated for ease of removal at a later period. I also removed the charcoal canister. We applied a new koyo rad to the car aswell as a 4inch fmic , this will help the cooling during the summer months. Why we choose the kayo to the fluidyn ?? the kayo is thicker and you can place an new bonnet without the worries of it not fitting properly as the fluidyn is noted for (various carbon bonnets that require bonnet pins). We also removed about an inch of muck on the engine bay , cant beleive how dirty this car was .. you need to keep it clean from now on ...unfortunately i cant shine the engine , it needs a serious clean and the tb/manifold needs polishing . All the coil pack clips were shot , so i replaced all of them, the seal for the intake manifold had a kink in it , so we had to replace this. overall the job was not a straight forward as i imaged, but you have to take this into consideration it is a "L" REG car, things are bound to have wear and tear on it .... Tuning is on friday , so ill post the graph up on monday Link to comment Share on other sites More sharing options...
michel lane Posted March 26, 2007 Author Share Posted March 26, 2007 Here are some pics of another customer engine that iam putting together. This is based on the bottom end i have for sale. Just a reminder i can organise installation and tuning of all engines or single turbo conversions done by myself. We are looking for around the 700hp for this engine on standard pump gas. Link to comment Share on other sites More sharing options...
michel lane Posted March 26, 2007 Author Share Posted March 26, 2007 bump Link to comment Share on other sites More sharing options...
tbourner Posted March 26, 2007 Share Posted March 26, 2007 Cool, sounds like it's going well even with a few issues! Looking forward to the final result. Link to comment Share on other sites More sharing options...
SupraAyf Posted March 26, 2007 Share Posted March 26, 2007 Great thread Michel - can't wait to see the results of the graph. Link to comment Share on other sites More sharing options...
b_have Posted March 26, 2007 Share Posted March 26, 2007 Nice work Michel. Link to comment Share on other sites More sharing options...
wkdtime Posted March 26, 2007 Share Posted March 26, 2007 Hehe, the pics i have been waiting for, looking very nice:) Michel once again your a gem of a guy for sorting out a few of the problems that i wasn't even aware of and keeping me posted at every step. Link to comment Share on other sites More sharing options...
Sheefa Posted March 26, 2007 Share Posted March 26, 2007 Great job Michel WKDTime, looks like you're pretty muh getting a NEW Car with everything sorted buddy running in tip-top! Lucky bugger. Link to comment Share on other sites More sharing options...
Tom Posted March 26, 2007 Share Posted March 26, 2007 The engine was held in place with one mount , the other had was not bolted to the car, because the main hanger was broken Just a bit worrying! Link to comment Share on other sites More sharing options...
