Full Single Turbo Install
michel lane
  • Replies 92
As said in the other thread, fancy putting a video of it together...
Hell, I'll chip in for tapes and you can even borrow my old vid camera, I'm sure there are enough people here who would help edit all the crud out of it.
What do you reckon?
Video sounds like a lot of hassle and expense for very little gain over photos. Some static video is never going to show much detail and anything else would be a PITA for Michel to do while trying to get on with the job.
Hows your project comming along?
work starts at turbofit this month just finalising some dates with them to move the donor 6 speed up there and pull the motor and box.
Then i need to get over to cj to pick up he aerotop i brought from him then strip that engine bay sprayed and body kit fitted engine box in then to my bodyshop for the respray back to turbofit for final mapping then to my workshop for the interior:d
spec
greddy t78
hks rail
hks 1000cc injectors
twin pumps
twin feeds
aeromotive fpr
electric twin fans
fluidyne rad
hks cams
twin hks ssqs
etc etc:p
Guest dee_rz
Does sound a very good price all in for what you listed infact it seems to little to budget but i'm sure you have talked it through, your in good hands michel is a good man and very helpful :) :cool: keep us posted :cool: :eyebrows: :)
Some of the parts are second hand like the DP and Mid pipe, all the important bits are new and he's charging very very little for the install:D
Also i already have the FMIC, Gauges, EBC, AFR etc.
  • 3 weeks later...
More updates,
Below is the exact spec for the build so far, it may change.
SP MANIFOLD
HKS 60 MM wastegate
4 inch intake pipe
4 inch dp/mp
Precision polished SP67 .68ar TURBO
Clamps / oil lines / return lines /filter.
Fuel kit
Aeromotive FPR
Aeromotive rail
Walbro Dual fuel pump
Precision(dephi) 880cc injectors
Fuel filter
-6 braided lines
Relays
MAP ECU
And pics,
