Tricky-Ricky Posted January 4, 2007 Share Posted January 4, 2007 I'm wondering whether to fit a front Tein strut brace, two things make me hesitate, one i plan to go single at some point and don't know if it will foul the turbo, and two, i'm not completely sure if it necessary, as the Supra uses double wishbone arrangement, so most of the forces involved are concentrated much closer to the chassis members, not at the top of the damper anchor point like McPherson struts, anyone like to comment? Quote Link to comment Share on other sites More sharing options...
Pete Posted January 4, 2007 Share Posted January 4, 2007 1) You can take it back off. It's only a 10 min job. 2) Try it and see. ChrisW says he noticed naff all improvement in handling on ones he tried. A benefit for aerotops (anything to help on there), not so noticeable on tin tops. I just got mine today so I'll let you know. (Only bought as it was cheap, shiny and I'm curious) Quote Link to comment Share on other sites More sharing options...
hadyn Posted January 4, 2007 Share Posted January 4, 2007 My main reservation for not fitting a strut brace would be that the bloody thing gets in the way when your changing plugs surely? Quote Link to comment Share on other sites More sharing options...
JODY T Posted January 4, 2007 Share Posted January 4, 2007 Hmmm, Ide go for the TEIN brace, front and Rear... I have the TEIN SUperstreet and i honestly did notice a difference especially throwing the front end into corners, It seems to feel more stable which gives confidence... I dont think you will have a problem with them fouling anything in the engine bay either... The TRD ones seem to sit a little lower than the TEINS... Its also designed so you can use the EDFC too... They look good too I have the fronts in stock for next day delivery right now... Quote Link to comment Share on other sites More sharing options...
mr lover Posted January 4, 2007 Share Posted January 4, 2007 tein one here with a single http://www.mkivsupra.net/vbb/attachment.php?attachmentid=45553&d=1161091545 peter p i think Quote Link to comment Share on other sites More sharing options...
DamanC Posted January 4, 2007 Share Posted January 4, 2007 Hmmm, Ide go for the TEIN brace, front and Rear... I have the TEIN SUperstreet and i honestly did notice a difference especially throwing the front end into corners, It seems to feel more stable which gives confidence... I dont think you will have a problem with them fouling anything in the engine bay either... The TRD ones seem to sit a little lower than the TEINS... Its also designed so you can use the EDFC too... They look good too I have the fronts in stock for next day delivery right now... Is mkivstore open today Jody? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 4, 2007 Author Share Posted January 4, 2007 So it looks like it will fit with a single, but does it actually stiffen things up enough to really notice a difference? Quote Link to comment Share on other sites More sharing options...
JODY T Posted January 4, 2007 Share Posted January 4, 2007 Yes IMO you will feel the difference.. worth the money... I have these on my car.. Quote Link to comment Share on other sites More sharing options...
Suprash Posted January 4, 2007 Share Posted January 4, 2007 I havent noticed the difference, but then Im not a pro driver, but I put mine on mainly for show...... Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted January 4, 2007 Share Posted January 4, 2007 .. Quote Link to comment Share on other sites More sharing options...
Homer Posted January 4, 2007 Share Posted January 4, 2007 Had a cusco one on mine, it made bugger all difference. Quote Link to comment Share on other sites More sharing options...
