JamieP Posted January 2, 2007 Share Posted January 2, 2007 My boost has dropped from 0.8 bar to 0.6 bar today,(0.6 bar wastegate spring) ive checked the boost solenoid and all the wires seem fine.. Any ideas? Quote Link to comment Share on other sites More sharing options...
Alex Posted January 2, 2007 Share Posted January 2, 2007 Your wastegate spring is buggered? Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 2, 2007 Author Share Posted January 2, 2007 Should i try and tighten the wastegate and see if that raises the boost or bad idea? Quote Link to comment Share on other sites More sharing options...
Alex Posted January 2, 2007 Share Posted January 2, 2007 Is it actually an adjustable one or just one with the corrolating screw, that actually isn't connected to anything. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 2, 2007 Author Share Posted January 2, 2007 The wastegate ia adjustable... i never use to have a boost controler. Quote Link to comment Share on other sites More sharing options...
Alex Posted January 2, 2007 Share Posted January 2, 2007 Then I'd try that first... Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted January 2, 2007 Share Posted January 2, 2007 My boost has dropped from 0.8 bar to 0.6 bar today,(0.6 bar wastegate spring) ive checked the boost solenoid and all the wires seem fine.. Any ideas? any chance it could be something else but not the spring ie loose hose ?? Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 2, 2007 Author Share Posted January 2, 2007 Ok thanks Alex, ill try it now. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 2, 2007 Author Share Posted January 2, 2007 any chance it could be something else but not the spring ie loose hose ?? Checked all hoses and they seem fine... maybe the solenoid has packed in... only other thing is i wonder if it has anything to do with the TPS, as i know my boost is also controled by how far i put my foot down. Quote Link to comment Share on other sites More sharing options...
Alex Posted January 2, 2007 Share Posted January 2, 2007 Opps too slow. Sometimes the holes can be very small... Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 2, 2007 Author Share Posted January 2, 2007 Ok ill go double check hoses... back in min. Quote Link to comment Share on other sites More sharing options...
Alex Posted January 2, 2007 Share Posted January 2, 2007 Probably best to use water and look for bubbles when the engine is running...IYSWIM Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 2, 2007 Author Share Posted January 2, 2007 Right as far as i can see all the pipes are fine, also i can hear the boost switch click on and of with the ignition. getting dark now so ill try the bubble trick tomorrow. Whats IYSWIM? Thanks. Quote Link to comment Share on other sites More sharing options...
Class One Posted January 2, 2007 Share Posted January 2, 2007 If You See What I Mean. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 2, 2007 Author Share Posted January 2, 2007 If You See What I Mean. Thanks:) Quote Link to comment Share on other sites More sharing options...
Ian C Posted January 2, 2007 Share Posted January 2, 2007 You could try turning up the boost (via the boost controller) a bit and seeing if it has an effect - if it doesn't then the problem would seem to lie with the EBC. -Ian Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 2, 2007 Author Share Posted January 2, 2007 You could try turning up the boost (via the boost controller) a bit and seeing if it has an effect - if it doesn't then the problem would seem to lie with the EBC. -Ian Its a aem solenoid controled by the AEM ecu.. no in car adjustment yet, i have to run a few switches back to the ECU for my next visit. Quote Link to comment Share on other sites More sharing options...
michel lane Posted January 2, 2007 Share Posted January 2, 2007 what type of wastegate do you have ?? if its the ebay hks copy , then thats your problem. You should not have any problems with the solinode for the aem . Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 2, 2007 Author Share Posted January 2, 2007 Wastegate is a proper hks 50mm Quote Link to comment Share on other sites More sharing options...
michel lane Posted January 2, 2007 Share Posted January 2, 2007 did you have a filter from the wastegate to the gm solinode ??otherwise you may has some crap in the unit .. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 2, 2007 Author Share Posted January 2, 2007 did you have a filter from the wastegate to the gm solinode ??otherwise you may has some crap in the unit .. Hmm good point... i wondered what that little filter was:D Think we may have found the problem. Ill check it out tomorrow. Quote Link to comment Share on other sites More sharing options...
Ian C Posted January 3, 2007 Share Posted January 3, 2007 First time I've heard of having an inline filter in the boost control hoses I'm not saying you don't need one, I know the HKS BOV has one, but I don't know of anyone else running one for their EBC solenoid... Worth checking the solenoid though. -Ian Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 3, 2007 Author Share Posted January 3, 2007 I see, well there was one in the old pipework, when i changed to red pipework i didnt bother swaping it over. Not had a chance to check it out yet but ill report back with my findings. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 6, 2007 Author Share Posted January 6, 2007 Turned out to be broken boost solenoid... new one on order, thanks for the help guys. Quote Link to comment Share on other sites More sharing options...
