Supra Steve 856 Posted December 29, 2006 Share Posted December 29, 2006 Hi Guys, Do any of you have a set of Glass headlights for sale?? I recently had a front end smash and my old jspec (plastic) ones got smashed, i always said to myself if the got damaged i would replace them with the glass set. Does anyone have some for sale and if so how much?? Thanks, steve Link to comment Share on other sites More sharing options...
Class One Posted December 29, 2006 Share Posted December 29, 2006 You're best trying Steve Manley at Inchcape Toyota, IIRC they're around £240 a set. Link to comment Share on other sites More sharing options...
Todd Posted December 29, 2006 Share Posted December 29, 2006 or Nic http://www.mkivsupra.net/vbb/showthread.php?t=76750 Link to comment Share on other sites More sharing options...
Nic Posted December 29, 2006 Share Posted December 29, 2006 or Nic http://www.mkivsupra.net/vbb/showthread.php?t=76750 Thanks Todd The UK glass headlights actually work out a little cheaper buying locally, once postage is added from here. It is only the facelift headlights that I can supply quite a bit cheaper. Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted December 29, 2006 Share Posted December 29, 2006 I'd go for facelifts if it was me but if you want glass ones, then THESE are a good price (if they are still available) Link to comment Share on other sites More sharing options...
jayssupra Posted December 29, 2006 Share Posted December 29, 2006 I thought facelift headlights where glass, so whats the differance between facelift and j-pec Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted December 29, 2006 Share Posted December 29, 2006 I thought facelift headlights where glass, so whats the differance between facelift and j-pec uk (glass) headlights and pre facelift (plastic) j-spec headlights both have the same markings on the lens, the only difference between them is one is glass and one is plastic (also the uk headlight has a electric adjuster on the back) the facelift headlights are plastic, but there are less makings on the lenses, and the insides are a dark graphite grey colour Link to comment Share on other sites More sharing options...
Lewis Posted December 29, 2006 Share Posted December 29, 2006 uk (glass) headlights and pre facelift (plastic) j-spec headlights both have the same markings on the lens, the only difference between them is one is glass and one is plastic (also the uk headlight has a electric adjuster on the back) the facelift headlights are plastic, but there are less makings on the lenses, and the insides are a dark graphite grey colour Any nearer to being able to glass front my facelifts? I asked the question a while ago and you weren't too sure, just wondered if it was something you would consider giving a go, I have facelifts and would happily chop a set of uk's for the glass. Link to comment Share on other sites More sharing options...
jayssupra Posted December 29, 2006 Share Posted December 29, 2006 Thanks mate, that clears thing up Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted December 29, 2006 Share Posted December 29, 2006 Any nearer to being able to glass front my facelifts? I asked the question a while ago and you weren't too sure, just wondered if it was something you would consider giving a go, I have facelifts and would happily chop a set of uk's for the glass. i remember i'm actually doing a set this weekend for a member, the only way this can be done is to pull apart a set of facelift lights to get the inside (plastic chrome) part. the it need trimming and cutting to fit inside the uk light, that's the only way of doing this as they are very different in construction. i'll let you know the outcome when they're finnished Link to comment Share on other sites More sharing options...
Lewis Posted December 31, 2006 Share Posted December 31, 2006 i remember i'm actually doing a set this weekend for a member, the only way this can be done is to pull apart a set of facelift lights to get the inside (plastic chrome) part. the it need trimming and cutting to fit inside the uk light, that's the only way of doing this as they are very different in construction. i'll let you know the outcome when they're finnished If you could, with prices too if you purleese Cheers Link to comment Share on other sites More sharing options...
