boromfccup Posted December 28, 2006 Share Posted December 28, 2006 hi im decating my tt is it best to put a 1.2bar rr in and no ebc or have a 1.0 bar rr and raise it up to 1.2 bar with the ebc thanks its a jspec Quote Link to comment Share on other sites More sharing options...
jamesmark Posted December 28, 2006 Share Posted December 28, 2006 If you are Jspec it is best to do 1.2 bar, you might not even hit 1.2 bar after a full decat. If you are UK spec then you do not need a RR just an BC. Quote Link to comment Share on other sites More sharing options...
chris burford Posted December 28, 2006 Share Posted December 28, 2006 hi im decating my tt is it best to put a 1.2bar rr in and no ebc or have a 1.0 bar rr and raise it up to 1.2 bar with the ebc thanks Hi mate firstly is your soop a jspec or a uk tt. Quote Link to comment Share on other sites More sharing options...
chris burford Posted December 28, 2006 Share Posted December 28, 2006 If you are Jspec it is best to do 1.2 bar, you might not even hit 1.2 bar after a full decat. If you are UK spec then you do not need a RR just an BC. Hi james am i right in thinking that on the jspecs if you were to put a 1.0 bar rr in you wouldnt be able to raise the boost to 1.2 bar with an ebc anyway. cheers chris. Quote Link to comment Share on other sites More sharing options...
jamesmark Posted December 28, 2006 Share Posted December 28, 2006 Hi james am i right in thinking that on the jspecs if you were to put a 1.0 bar rr in you wouldnt be able to raise the boost to 1.2 bar with an ebc anyway. cheers chris. iirc I think you cant, but I aint sure tbh just always go for the tried and tested which is the 1.2 bar RR and then BC too or at a later date. Quote Link to comment Share on other sites More sharing options...
Jake Posted December 28, 2006 Share Posted December 28, 2006 am i right in thinking that on the jspecs if you were to put a 1.0 bar rr in you wouldnt be able to raise the boost to 1.2 bar with an ebc anyway. No, that's incorrect. With an EBC you could raise the boost regardless of restrictor ring or even cats. It's not a good idea to do it with the cats in though. Quote Link to comment Share on other sites More sharing options...
boromfccup Posted December 28, 2006 Author Share Posted December 28, 2006 so is that best a 1.0 bar rr and an ebc to raise it to 1.2 max Quote Link to comment Share on other sites More sharing options...
Class One Posted December 28, 2006 Share Posted December 28, 2006 so is that best a 1.0 bar rr and an ebc to raise it to 1.2 max It's not a question of best, but of what suits you and your driving style, however, if you have j spec tubbies, then this maybe the better of the two options to, maybe, (as there are NO guarantees) to prolong the life of your tubbies. Quote Link to comment Share on other sites More sharing options...
chris burford Posted December 28, 2006 Share Posted December 28, 2006 No, that's incorrect. With an EBC you could raise the boost regardless of restrictor ring or even cats. It's not a good idea to do it with the cats in though.Cheers Jake you do learn something everyday so what does the rr actually do then, does it stop spiking damn this thirst for knowledge is drowning me. chris Quote Link to comment Share on other sites More sharing options...
Nic Posted December 28, 2006 Share Posted December 28, 2006 so is that best a 1.0 bar rr and an ebc to raise it to 1.2 max This would be my preferred set up, as it gives you more control of the boost. In the winter you will see slightly higher boost than in the summer, so the Electronic Boost Controller gives you the control to adjust peak boost as desired or the option of reducing boost back to 1.0-1.1bar if needed. A good quality EBC also allows you to set up the gain, which will increase the speed the turbos spool up. Some EBC's also allow you to set boost against speed signal, so you can maximise boost through each gear, ie. you can get peak boost in 1st gear and 6th gear. Without the EBC you would need to set peak boost for higher gears and which would produce lower boost through lower gears. If you need any recommendations on which EBC to go for and prices, please let me know. Quote Link to comment Share on other sites More sharing options...
