First stage of headlight duct completed
Wez
Hey All,
A friend of mine completed the first part of my headlight mod today, its now down to me to seal it and finish it off, cant decide if I should paint the pipe/duct black or not.
He done a good job and getting the pipework and lense cut.
The duct is based on a 4" pipe which I hope to connect up to a sealed airbox like the Viper unit shown below.
Hopefully no more hot engine bay air for me :cool:
When finished it should look something like the one of the red car.
I am going to use some black windscreen sealer which should hopefully do the trick :D
thats what i did Wez, make sure you heat it up in the oven first the same as spliting it, drown it in sealer then get brutal to make sure its mated properly, mine misted up slightly for a day then has been clear ever since
Guest CoolsBlue
yeah thought that would be the case, just anwsering the mans question :)
what you gonna do when it rains?! surly water going stright into the filter is not good.
hmmm good point there, could have the pipe and a slant so a bit of rain will poor back out, helps a little even though rain can still get in.
Wow, didnt know they used a stock filter on the toms supra!!
The OEM filters must flow like a mofo!
It's not a stock filter, close and that's what I first thought. It does look paper based.
The stock paper filter runs in multiple rows of horizontal strips rather than the two rows of vertical strips. ;)
