superpaulwilson Posted December 26, 2006 Share Posted December 26, 2006 Blown the fuse when jump starting - anyone know how to get it out??? Quote Link to comment Share on other sites More sharing options...
Guest leeshell Posted January 19, 2007 Share Posted January 19, 2007 Disconnect the battery. Remove the fuse board cover. Remove 3 bolts (10mm) retaining the fuse board. Lift the fuse board - underneath, either side of the 120 Amp fuse, remove the bolt (13mm) which is passed through the 120 Amp fuse legs. Quote Link to comment Share on other sites More sharing options...
nad300 Posted January 20, 2007 Share Posted January 20, 2007 Is that the white fuse with see through top ?? if yes its a fusible link part number y90982-08271 cost me £13.35p inc vat from local dealers Quote Link to comment Share on other sites More sharing options...
gordy.r Posted April 23, 2017 Share Posted April 23, 2017 Holy thread revival!!! Think this has just happened to me.... Went to jump start the Supra this afternoon, dash lights came on once all connected up with the leads, turned the key to start and there was crack noise came from the engine bay and then there was no power at all to the car. Tried the leads again and nowt. Decided to leave it for another day but after a bit of research have discovered it may be the 120A fuse that has blown. Anyone else experienced this and had to swap one out? Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted April 23, 2017 Share Posted April 23, 2017 Happened to me years ago on my first Supra, new fuse in, job done! Quote Link to comment Share on other sites More sharing options...
