j-spec downpipe?
speddynille
Im wondering somethings about the j-spec downpipe!
Many people who say different things.
Do you have to have one cat left or a restrictor plate?
If you have a boost controller wont that solve the problem so it wont boost over 1,2 bar?
I have just installed a hks evc5 bc in my car, and are going to buy a downpipe but need to sort this out first.
What's the availability of bigger wastegates for the J Spec, say if the turbo is removed & machined to a bigger hole??
Anyone tried this? I'm guessing that there's a limit on the diameter it can go to. Would the UK spec wastgate valve head fit onto the J spec actuator shaft??
I think some hybrid turbos are machined with a bigger wastegates.
I have seen quite a few stock j-spec turbos with cracks on the casting on the edge of the wastegate. It seems to be a weak point on the casting, which would only get weaker if the wastegate was increased in size.
