Front end damaged, sensors???????
johnd-mkiv
I have bought another supra thats had a bad front end smash, the engine still spins over but will not run was told by the owner this is because of sensors in the front is this true? if so where are they located can they be bypassed .
Not had a chance to look into it yet but thought I would get a bit of knowledge before I do.
its a 1993 K reg aero top auto
There is a crank sensor right behind the crank pulley, sort of on the passenger side. Have you checked to see if there is spark, or if the fuel pump is running?
not had a look at the engine yet will be doing that today just wondering if there is some crash sensors on it before I start
