Networking question
Jake
I'm at my sister's place, she's got NTL cable TV and broadband through a set top box and a PC connected to the net via network cable to the STB.
She's now got an additional PC for her kids and wants that to also be able to connect the intarwebs with her cable internet
but the STB only has a single port for a network cable.
So what do I need to buy to enable two PCs to have a wired connection to a STB?
Cheers guys
  Jake said:
Would both PCs have different IP addresses if I did it that way?
Would PCs having the same IP cause problems?
If both are set to DHCP then they should pick up different IP's.
Each PC's IP address has to be unique on your network.
Have run routers in Telewest setups but there the network is presented via a coax cable and this is then stuck into a router/firewall (Linksys).
You can run a router if you wish though would give you the ability of an additional firewall and layer 3 trickery.
  Alex said:
But do routers work on cable?
Yup absolutely. plug your CAT5 port (internet facing) of your router into the CAT5 port on the cable modem. then plug your pc's behind the router (internal interface - most routers will have an inbuilt switch)
PC > HOME ROUTER (NAT ENABLED) > CABLE MODEM (cat5) > INTERNET
Yep - that'll do the job.
You'll need to clone the existing PCs MAC address in the router setup before you can get it to work though. NTL only allow one MAC address to work at a time (hence the need to get routers that are compatible with NTL). Connect the PC to the router and in settings somewhere will be a "Clone connected MAC address" setting.
  Jake said:
We've gone for this router : http://www.novatech.co.uk/novatech/specpage.html?LIN-BEFSR8
I hope that'll work (will it Gavan?) because I've sent my Bro In Law to go get one!
Yup, that is spot on, I used EXACTLY that unit on my NTL cable line originally... absolute doddle to setup and get running.. and for £25 you just can't go wrong.. Drop me a PM if you get stuck setting it up (although I seriously doubt you will)
PS : Wow, very impressed, spelt my name properly, be amazed how many people don't *grin* (Well chuffed)
you don't ALWAYS need to clone the mac, I've found with mine, if I turn the STB or NTL modem for 5 minutes or so then it works fine...
The MAC cloning does work if you want to get it running quickly..
Im pretty sure NTL will allow multiple connections through the same STB. When you connect up it will ask you for your connections details and password and you just do that twice, once for each connection.
Or you use the router and first time one of the computers connects it will ask for those details, at that point its getting the address of the router so whichever computer connects through that router will then work.
I run a wireless router on NTL cable with a STB and have not needed to clone the mac address.
JB
