big neil LSD Posted December 19, 2006 Share Posted December 19, 2006 do these just pull of dont wanta go heavy handed and lose paint. and were do i get a new set got 1 broke today. new are second hand thansk neil Quote Link to comment Share on other sites More sharing options...
AlanM Posted December 19, 2006 Share Posted December 19, 2006 Aye, they are just stuck on, gently prise them off from one end, mine came off quite easy. Bit of a bugger getting all the glue off the paitwork afterwards though. I never ever put the new ones on, preferred the look without them Quote Link to comment Share on other sites More sharing options...
Angarak Posted December 19, 2006 Share Posted December 19, 2006 JezzyBabes may have a pair of second hand ones, or the likes of Miami-GT and Nic can get new ones. The double-sided sticky tape is a bugger to get off the black plastic trim that the wind deflectors sit on, but they do scrub up quite well. I removed mine starting from the rear of the wind deflector, the clip at the front of the deflector is positioned differently to the rest...so if you remove it in a clockwise direction from the rear you should reduce/eliminate any chance of marking your paint work. Quote Link to comment Share on other sites More sharing options...
big neil LSD Posted December 20, 2006 Author Share Posted December 20, 2006 cheers started it today.yeah the glue is hard to get of. and also the owner before has added some other crap like paste ahwel thanks again Quote Link to comment Share on other sites More sharing options...
