Drivers Side Door Skin
Dave Haggas
Please excuse the stupid question but what is the skin of the door? My understanding is that the door is 'one piece'....
Erm...the door is as you say one piece,but it has a frame and then a skin.The skin is everything you see from the outside when the door is closed.
If you have ,say,some bubbling at the outer lower edge of the door,it could be rusting from the inside.So you would grind the oxidised metal and replace with clean metal locally.The nicer alternative is to remove the outer skin and replace.
Also if your door is dented badly a new skin could be the answer.
A new skin from Toyota is £210.00.
I do hope this helps.
