Guest CoolsBlue Posted December 18, 2006 Share Posted December 18, 2006 anyone got pics of UK brakes on a N/A? i want to put these on my supra, but hear theyre very pricey, pics? Quote Link to comment Share on other sites More sharing options...
lockys96 Posted December 18, 2006 Share Posted December 18, 2006 just look for any supra with uk brakes for pics Quote Link to comment Share on other sites More sharing options...
Pot Posted December 18, 2006 Share Posted December 18, 2006 A supplemental question if I may - Are they worth the ££ in putting them on (Apart from the look)... Quote Link to comment Share on other sites More sharing options...
Guest blueangel Posted December 18, 2006 Share Posted December 18, 2006 lol er yeah you would stop quicker Quote Link to comment Share on other sites More sharing options...
Jake Posted December 18, 2006 Share Posted December 18, 2006 Are they worth the ££ in putting them on (Apart from the look)...It's a matter of opinion. Personally, I always found the j-spec brakes were adequate for road use provided that they had good quality fluid, pads and lines. However the first time I put a Supra around a track they faded really badly and actually caught fire. The UK's are a lot better in regard to fade resistance and a bit better on the road. ...and they look great too! Quote Link to comment Share on other sites More sharing options...
Pot Posted December 18, 2006 Share Posted December 18, 2006 Guess I asked for that... lol How about, is it worth the cost to get UK Brakes (The items, wheels that fit around them, plus fitting, everything needed) worth any extra stopping power vs aftermarket kit that will go straight onto a J-Spec?... Quote Link to comment Share on other sites More sharing options...
Pot Posted December 18, 2006 Share Posted December 18, 2006 However the first time I put a Supra around a track they faded really badly and actually caught fire. Jesus... (Starts looking for upgrades before he considers doing the ring)... Quote Link to comment Share on other sites More sharing options...
Scooter Posted December 18, 2006 Share Posted December 18, 2006 I recently did a track day at brands with J-spec brakes and uprated pads and they were fine. I think that in a one off stop the jap and Uk's are all but the same in that both will cause the ABS to cut in ie both can perform the max retardation the tyres can hold. Where they are far better is continuous and hard applications ie the track. I would say though that my j-spec calipers with CW race pads would last better at the track than stock uk's with stock pads. My take on a NA with Jap brakes is that i would only consider upgrading to UK's when my calipers (that are prone to seized sliders) or disks (preferably both!) were shot...... Different pads in j-spec brakes can transform the brakes feel and the resistance to fade. Quote Link to comment Share on other sites More sharing options...
squiffy Posted December 18, 2006 Share Posted December 18, 2006 i found the j-spec brakes on my n/a absolutely fine for road use, its only now i have the tt i really think i need to upgrade! Quote Link to comment Share on other sites More sharing options...
Nic Posted December 19, 2006 Share Posted December 19, 2006 anyone got pics of UK brakes on a N/A? i want to put these on my supra, but hear theyre very pricey, pics? I supply the brakes for the following prices new. Front 4 pot calipers, shim kit and fitting kit = £385 including postage to UK (2-3 days). Rear 2 Pot calipers and fitting kit = £385 including postage to UK (2-3 days). Front and Rear calipers = £750 including postage (2-3 days). If you are prepared to wait I could save some money by sending them by surface post, this would take around 4-5 weeks to UK. Discs are very heavy and expensive to post, so better to buy there. I can also supply pads if needed (TRD, Project MU, Endless, etc.) Quote Link to comment Share on other sites More sharing options...
Scoboblio Posted December 19, 2006 Share Posted December 19, 2006 I must've had some seriously bad pads / disks / fluid when I had my J-specs, because they were quite simply awful. From 50 or 60mph they would perform a few emergency stops quite happily, but any type of spirited driving at all would see them fade frighteningly fast. The UK setup was a hug improvement, then again I did go for fluid, lines, pads, calipers, disks etc all at the same time. Quote Link to comment Share on other sites More sharing options...
rovervi Posted December 19, 2006 Share Posted December 19, 2006 anyone got pics of UK brakes on a N/A? i want to put these on my supra, but hear theyre very pricey, pics? see my garage, i think you can see them, a bit at least Quote Link to comment Share on other sites More sharing options...
hulse Posted December 19, 2006 Share Posted December 19, 2006 heres my uks http://i94.photobucket.com/albums/l95/hulse_2006/DSC00108.jpg Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted December 19, 2006 Share Posted December 19, 2006 Doesn't matter if the supe is N/A or TT. If you consistently take the car above 100 leptons then yes the UK brake setup is a must. Brake fade from 100 plus on J-spec brakes is awfull. Now you all could say that nobody on here does that kind of speed governor. Bear in mind that whatever speed you are doing you will need to know that you can come to a complete stop from that speed if required IN A SAFE DISTANCE and at over a ton J-spec brakes don't cut the mustard. Race spec pads on J-spec brakes is all well and good but they need to be warm to function properly which is fine on a track but not on a spririted drive lets say on a motorway where touching the brake pedal is furthest from your mind. For the money its the first mod I would do to any J-spec braked car. Quote Link to comment Share on other sites More sharing options...
mathew Posted December 19, 2006 Share Posted December 19, 2006 were bigger brakes an option on j spec cars? Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted December 19, 2006 Share Posted December 19, 2006 They came as standard on the GZ's and RZ's I beleive Quote Link to comment Share on other sites More sharing options...
mathew Posted December 19, 2006 Share Posted December 19, 2006 its just that mine look just like rovervi's and he stated that his are uk. il try and get some pics up Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted December 19, 2006 Share Posted December 19, 2006 Ones in your garage yes they are UK spec brakes mate. Maybe cos its a facelift NA?? Maybe an option. Maybe retrofit but yes UK spec brakes. Quote Link to comment Share on other sites More sharing options...
mathew Posted December 19, 2006 Share Posted December 19, 2006 great stuff! Quote Link to comment Share on other sites More sharing options...
