jawan Posted December 18, 2006 Share Posted December 18, 2006 Hi, what is the disc size for 93 j spec TT, normally on websites its for 16" alloys or 17" alloys. Does it mean 16 for jap and 17 for uk spec than:tongue: ks Link to comment Share on other sites More sharing options...
Nic Posted December 19, 2006 Share Posted December 19, 2006 Hi, what is the disc size for 93 j spec TT, normally on websites its for 16" alloys or 17" alloys. Does it mean 16 for jap and 17 for uk spec than:tongue: ks The Supra was fitted with 2 sizes of brakes, the larger brakes were an option on early J-spec Supras and standard on later J-spec models. The UK Supra came with the larger brakes as standard. The larger brakes will not fit behind the standard 16" wheels, only the standard 17" wheels. Not all Supras with 17" wheels will necessarily have the larger brakes fitted. Smaller Spec Brakes Front 2 pot, with 296mm diameter discs Rear 1 pot, with 307mm diameter discs Larger Spec Brakes Front 4 pot, with 323mm diameter discs Rear 2 pot, with 324mm diameter discs Link to comment Share on other sites More sharing options...
