Does number 2 turbo forget to come on?
hadyn
I know all about checking VSV and hoses etc to look for leaks that might be causing number 2 not to come on...
But tonight, I accelerated quite briskly stomping my foot to floor and didnt get any number 2 turbo from 4k rpm. Car revved through the rev-range upto the limiter but got a slight bump "like a less violent fuel cut feeling" before I backed off.
Strangely, everything seems fine again now and number 2 is prespooling and boosting as it should. Does the system sometimes become 'stuck'?
Mine seems to be working fine too but I've been told over and over that it is highly unlikely to be anything else.
You get an increase in revs but increase in speed. Am I right?
If so, then how? How can your revs increase without an increase in road speed? You'd either have to be wheelspinning or in neutral. Seems more likely that the box is slipping under heavy torque situations.
Mine did this since I bought it 3 years ago. It's caused by one of the vsv of actuators sticking (can't remember which one) and stopping the 2nd turbo from coming online. Release/reapply the throttle and its sorted.
Its a very common issue.
BTW, its not a good idea to keep your foot to the floor when this happens as it'll overspeed the 1st turbo
EGBV caused this on mine. First demand for No-2 and it sluggishly revs, lift off then on or change gear and it's fine.
The vsv was a bit fecked and the EGBV actuator was seized giving a good crack when I released it. Mine started it one day then just got worse and worse until it was everytime I wanted tubby 2 after a while.
Well just had a quick play with the car this morning.
1st time i planted my foot cruisng at 50 ish leptons the same thing happened again - it felt like the 2nd turbo was asleep and wasnt playing ball again.
Thereafter on numerous 50ish 60ish lepton cruises I planted my foot to the floor and the 2nd turbo came on fine...........
I dont think its the autobox myself, but you do worry me redm!
