JDM Odometer
Angarak
I have a spare second hand Odometer for sale - Im looking/hoping for £30 delivered (within the UK).
I bought it to eliminate my original Odometer as the cause of a Code 42 error I had on my JDM Supra....which turned out to be a cut speed signal wire near my ECU in the footwell.
This Odometer does work (the solders are good), and has 93305km on the tripometer. It may be useful for anyone who also has a Code 42 error and suspects their Odometer as the culprit.
Im not sure if you can alter the tripometer reading should you wish to use it as a permanent replacement for your Odometer.
I will post some pictures in a bit. Picture added
Edit
Im not sure if there is a difference between pre-vvti and vvti JDM odometers, this odometer worked fine in my pre-vvti 95 RZ TT.
Cheers
Simon
