original_amo Posted December 16, 2006 Share Posted December 16, 2006 hey peeps need help as im going on the motorway tomrow and my dash lights are not workin. heaters all are just speedo rev and fuel. they went off after i changed a bulb. ive checked all fuses under the bonnet they are all gud. what can it be. is there another fuse box?? helps plz regards amo Link to comment Share on other sites More sharing options...
imi Posted December 16, 2006 Share Posted December 16, 2006 what bulb did you change? did you remove the dash, remove the speedo cluster plugs, if so then perhaps you didnt plug them in properly (do the needles function?) Link to comment Share on other sites More sharing options...
original_amo Posted December 16, 2006 Author Share Posted December 16, 2006 brake light Link to comment Share on other sites More sharing options...
original_amo Posted December 16, 2006 Author Share Posted December 16, 2006 ive cheked all the plugs for speedo etc still nuthing Link to comment Share on other sites More sharing options...
original_amo Posted December 16, 2006 Author Share Posted December 16, 2006 no fuses have been poped unless theres a fuse box in the car some were ? Link to comment Share on other sites More sharing options...
mr lover Posted December 16, 2006 Share Posted December 16, 2006 fuse box in drivers footwell right hand side Link to comment Share on other sites More sharing options...
Dave Posted December 16, 2006 Share Posted December 16, 2006 if they were all working before you took off the dash then something isnt pluged back in right and have you checked your dimmer switch is it turned right down ?????? Link to comment Share on other sites More sharing options...
original_amo Posted December 16, 2006 Author Share Posted December 16, 2006 thankz mate ill check that fuse box cheers Link to comment Share on other sites More sharing options...
original_amo Posted December 16, 2006 Author Share Posted December 16, 2006 ive turned the switch around etc. but the lights went out way before i tuched the dash?? Link to comment Share on other sites More sharing options...
Guest mk47 Posted December 16, 2006 Share Posted December 16, 2006 amo check the fuse box underneath the steering wheel to the right. Link to comment Share on other sites More sharing options...
original_amo Posted December 16, 2006 Author Share Posted December 16, 2006 thankz maz ill check that in the morning to dark now. but u reckon thats it? Link to comment Share on other sites More sharing options...
Dave Posted December 16, 2006 Share Posted December 16, 2006 heres a list of all the fuses m8 Link to comment Share on other sites More sharing options...
original_amo Posted December 16, 2006 Author Share Posted December 16, 2006 thankz dave appricated Link to comment Share on other sites More sharing options...
