gaz1 Posted December 16, 2006 Share Posted December 16, 2006 i have a toshiba laptop, and have a problem when i press the E key then E and I come up together also 7 does not work and a few others are not right is it fooked, easy repair, anyone Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted December 16, 2006 Share Posted December 16, 2006 try picking out the keys and see if theres anything stuck underneath that you can clean out Quote Link to comment Share on other sites More sharing options...
gaz1 Posted December 16, 2006 Author Share Posted December 16, 2006 try picking out the keys and see if theres anything stuck underneath that you can clean out mmm how do you get them out and how are they fixed in mate Quote Link to comment Share on other sites More sharing options...
gaz1 Posted December 16, 2006 Author Share Posted December 16, 2006 i did use a foam spray cleaner on them and think that may have buggered it:( Quote Link to comment Share on other sites More sharing options...
silvershark44 Posted December 16, 2006 Share Posted December 16, 2006 maybe just damp in there then. Try putting it in a warm place to dry it out Quote Link to comment Share on other sites More sharing options...
gaz1 Posted December 16, 2006 Author Share Posted December 16, 2006 maybe just damp in there then. Try putting it in a warm place to dry it out nah that was a week ago Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted December 16, 2006 Share Posted December 16, 2006 gaz if your careful you can usually just pop the keys right out, and they pop back into place again. try sticking somethin flat underneath (screwdriver?) maybe and gently pull them up. dont break them though Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted December 16, 2006 Share Posted December 16, 2006 yep gaz just stick a flat head screw driver underneath the key you want to take out, gently lift it and itll pop out. just tried it on mine (i dont have a laptop but the keyboard is exactly the same as a laptop one is) Quote Link to comment Share on other sites More sharing options...
gaz1 Posted December 16, 2006 Author Share Posted December 16, 2006 yep gaz just stick a flat head screw driver underneath the key you want to take out, gently lift it and itll pop out. just tried it on mine (i dont have a laptop but the keyboard is exactly the same as a laptop one is) gulp, will give it a try mate;) Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted December 16, 2006 Share Posted December 16, 2006 gulp, will give it a try mate;) should be fine. be careful you dont break anything though otherwise the laptop will malfunction and will be useless forever Quote Link to comment Share on other sites More sharing options...
mr lover Posted December 16, 2006 Share Posted December 16, 2006 otherwise the laptop will malfunction and will be useless forever no pressure then Quote Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted December 16, 2006 Share Posted December 16, 2006 what laptop is it? i had a dell laptop with a few keys not working, turned out to be the connector on the board come loose. it was i fiddley job but i managed to solder it i'm sure it's something simple though Quote Link to comment Share on other sites More sharing options...
gaz1 Posted December 16, 2006 Author Share Posted December 16, 2006 anyone know if its economically viable to get a new keyboard fitted to a laptop:D i have bits of mine all over the place:rolleyes: Quote Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted December 16, 2006 Share Posted December 16, 2006 anyone know if its economically viable to get a new keyboard fitted to a laptop:D i have bits of mine all over the place:rolleyes: you can pick them up fairly cheap, depends what laptop it is?? Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted December 16, 2006 Share Posted December 16, 2006 anyone know if its economically viable to get a new keyboard fitted to a laptop:D i have bits of mine all over the place:rolleyes: oh no Quote Link to comment Share on other sites More sharing options...
gaz1 Posted December 16, 2006 Author Share Posted December 16, 2006 you can pick them up fairly cheap, depends what laptop it is?? its toshiba sattelite but sausage fingers me would not be able to do it:( Quote Link to comment Share on other sites More sharing options...
