jonshaw_uk Posted May 29, 2004 Share Posted May 29, 2004 i dont know if this is just me or whether im not use to driving a supra (n/a manual) but when i go to pull of unless the revs are about 2k then the car jedders and makes a weird noise from the back end like im wheel spinning. If i rev at over 2k and pull off i have no noises or judders. I didnt remember this happening when i drove my dads before. It only happens in 1st gear and reverse. Has anybody got any ideas??? thanks Quote Link to comment Share on other sites More sharing options...
osso Posted May 29, 2004 Share Posted May 29, 2004 dodgy clutch, its probably worn, warped or you've got some crap on the flywheel maybe grease which causing part of the fly wheel to heat up giving you an uneven contact between the flywheel and clutch Quote Link to comment Share on other sites More sharing options...
jonshaw_uk Posted May 29, 2004 Author Share Posted May 29, 2004 thanks for the advice, how would i check the flywheel to see if there is a problem with it? The car has only done 48k miles would the clutch have gone? If so how much would i be looking at to replace it? thanks Quote Link to comment Share on other sites More sharing options...
osso Posted May 29, 2004 Share Posted May 29, 2004 I am afriad i have never seen the transmission system on a supra so i cant help you, end of the day im just an IT specialist.. Dude or Chris Wilson should be able to help you actually i think Chris Wilson is based in shropshire which is near you i think. Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted May 29, 2004 Share Posted May 29, 2004 Clutch could easily go with that mileage. I guess it's a gearbox out job (better than an engine out job). Quote Link to comment Share on other sites More sharing options...
s3upra Posted May 29, 2004 Share Posted May 29, 2004 before you rip out gearbox-is it j spec?does it have a speed delimiter on? if so try disconnecting it first.my j spec tt had EXACTLY the same problem,turned out to be this.good luck. Quote Link to comment Share on other sites More sharing options...
jonshaw_uk Posted May 30, 2004 Author Share Posted May 30, 2004 s3upra before you rip out gearbox-is it j spec?does it have a speed delimiter on? if so try disconnecting it first.my j spec tt had EXACTLY the same problem,turned out to be this.good luck. Thanks for the advice s3upra, the car is a j spec (48k miles on the clock) im not sure if it has a speed restrictor or not as ive only had the car for a week ad havent been brave enough to try to see what she can do. Where would i find the speed delimiter? Quote Link to comment Share on other sites More sharing options...
s3upra Posted May 30, 2004 Share Posted May 30, 2004 mine was in the passenger footwell,under the carpet,some are behind dash i think,if you do a search on here you can get more info. Quote Link to comment Share on other sites More sharing options...
