car judders when pulling off
jonshaw_uk
i dont know if this is just me or whether im not use to driving a supra (n/a manual) but when i go to pull of unless the revs are about 2k then the car jedders and makes a weird noise from the back end like im wheel spinning. If i rev at over 2k and pull off i have no noises or judders.
I didnt remember this happening when i drove my dads before. It only happens in 1st gear and reverse. Has anybody got any ideas???
thanks
I am afriad i have never seen the transmission system on a supra so i cant help you, end of the day im just an IT specialist.. Dude or Chris Wilson should be able to help you :thumbs: actually i think Chris Wilson is based in shropshire which is near you i think.
s3upra before you rip out gearbox-is it j spec?does it have a speed delimiter on? if so try disconnecting it first.my j spec tt had EXACTLY the same problem,turned out to be this.good luck.
Thanks for the advice s3upra, the car is a j spec (48k miles on the clock) im not sure if it has a speed restrictor or not as ive only had the car for a week ad havent been brave enough to try to see what she can do.
Where would i find the speed delimiter?
