scooby_doo_do Posted May 28, 2004 Share Posted May 28, 2004 Driving up to the NEC today and in 6th gear about 2.5 k revs accelerated (Peddle to floor), at this stage the revs went to about 4.5k revs freely before coming back down to about 3k when i noticed the car start to pull.... What on earth ?? Only seems to slip in 6th every now and then.. Only had the clutch replaced with a rsp kit about 2/3 years ago. Need the car ready for le mans Phoned up toyota who quoted me £600+, then i phoned Mr clutch who quoted me £550.... How long will the clutch last like this ? Do you think i'll only need the flywheel skimmed and the friction plate changing ? And will can i get it anywhere cheaper ! Craig, Quote Link to comment Share on other sites More sharing options...
scooby_doo_do Posted June 2, 2004 Author Share Posted June 2, 2004 According to my quote from toyota i need the clutch housing at £119, the bearing and the clutch plate... Do i really need the clutch housing ? as i bought a rsp clutch about 3 years ago and that was included in that ? Craig. Quote Link to comment Share on other sites More sharing options...
geoffvalenti Posted June 2, 2004 Share Posted June 2, 2004 Originally posted by scooby_doo_do According to my quote from toyota i need the clutch housing at £119, the bearing and the clutch plate... Do i really need the clutch housing ? as i bought a rsp clutch about 3 years ago and that was included in that ? Considering the labour costs involved in changing the clutch, not replacing all 3 parts is false economy IMHO. If you just want to bodge it up to sell it, then you may get away with it, if you're intending to keep it, its a no brainer Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 2, 2004 Share Posted June 2, 2004 we have a GB on RPS at the moment. Which RPS clutch was it. People have a tendancy to go for too much clutch, and they therefore have a shorter life. Quote Link to comment Share on other sites More sharing options...
Keith C Posted June 2, 2004 Share Posted June 2, 2004 I fitted one of Chris Wilson's uprated clutches and replaced the flywheel at the same time. With Chris doing the work it came to something like £900 or so, warrantied (although that goes if you drag race/track day). The clutch feels only a smidge heavier than stock, and will take more torque than stock, although I don't know how much. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 2, 2004 Share Posted June 2, 2004 They are generally between 10% -38% extra clamping force ( RPS) do you want the RPS max torque ratings? Quote Link to comment Share on other sites More sharing options...
Keith C Posted June 2, 2004 Share Posted June 2, 2004 Well, I don't know if it was an RPS one - I just know it was only a few quid more than a stock one and according to Chris 'a better clutch' Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 2, 2004 Share Posted June 2, 2004 all it will probably be is a stock clutch with a machined cover to give more clamping force. Will work just fine though for BPU cars. Quote Link to comment Share on other sites More sharing options...
scooby_doo_do Posted June 2, 2004 Author Share Posted June 2, 2004 This is the clutch i fitted 2/3 years ago... Just thought's i'd be able to use the blue bit still ? http://www.handsontraining.co.uk/supra/clutch1.jpg And this is the old one.... http://www.handsontraining.co.uk/supra/clutch2.jpg http://www.handsontraining.co.uk/supra/clutch3.jpg Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 2, 2004 Share Posted June 2, 2004 If you are in a rush, put the RPS cover back on and a new plate, but you really need to establish why it is slipping first. Is the the disc shagged or the cover?! Quote Link to comment Share on other sites More sharing options...
scooby_doo_do Posted June 2, 2004 Author Share Posted June 2, 2004 I don't think the flywheel was skimmed last time it was changed....As i paid £300 for the clutch change and the timing belt change as well. Quote Link to comment Share on other sites More sharing options...
scooby_doo_do Posted June 2, 2004 Author Share Posted June 2, 2004 Sorry to sound stupid, but what does the blue bit in the picture actually do ? I thought it was just a cover at first.. Quote Link to comment Share on other sites More sharing options...
SimonB Posted June 2, 2004 Share Posted June 2, 2004 Originally posted by scooby_doo_do Sorry to sound stupid, but what does the blue bit in the picture actually do ? I thought it was just a cover at first.. It presses the clutch disc against the flywheel. So the stronger the spring the harder is presses and the more friction. You pay for this with a harder pedal. The other thing that affects things is the coefficient of friction of the disc - in other words how grippy it is. Quote Link to comment Share on other sites More sharing options...
