sinbad Posted May 28, 2004 Share Posted May 28, 2004 Hopefully replacing shocks'n'springs in the next week or 2. Any thing simple in there I should do while its in little bits, bushes etc? Link to comment Share on other sites More sharing options...
matt Posted May 28, 2004 Share Posted May 28, 2004 There isn't really anything.that springs to mind.... unless you have some worn bushes in the front upper a arms. If you really want something to do .....paint your calipers or something:p Link to comment Share on other sites More sharing options...
Ian C Posted May 28, 2004 Share Posted May 28, 2004 Get all your subframe bolts tightened to the service manual torque figures. Easy job if the car is up and everything is off. -Ian Link to comment Share on other sites More sharing options...
womble Posted May 29, 2004 Share Posted May 29, 2004 Originally posted by Ian C Get all your subframe bolts tightened to the service manual torque figures. Easy job if the car is up and everything is off. -Ian Yeah for sure get this done, fronts and rears both worked lose on mine and made it handle like a shopping trolly ., Took it to C.W for sorting and he nearly ended up in a field in it !!. Link to comment Share on other sites More sharing options...
