Smokey Single
Marty
Ok but like Ricky says, you'll kill a wideband sensor if it's left in the exhaust whilst not connected to power.
The mapecu will not give any o2 reading without connecting up the AEM wideband. Not even the stock o2 sensor output is displayed. Where did you get the basemap? and what injectors are you running?
Ive not run it for long, just to check its working :)
i'll connect the wideband up then, silly of me not realising it was needed :rolleyes: Hopefully that should do the trick.
Lee--- im just using a basemap that came with the software for the 550 single supra engine, running the standard 550's until after xmas
Ahh its all coming to light;) first off don't believe the read out for the std lambda as its no very accurate, second it is only meant to tell the ECU if the AFR is varying from stoic 14.7 AFR also its signal should not really have any adverse affect on the ECU as its in effect just a switch, is the ECU stand alone of piggyback? you need to get your AEM wired up and running, also you may risk killing the wide band sensor if you have not got it powered up with its heater on:blink:
The ecu is a piggyback, gets rid of the maf senosor on the uk spec and also controls the fueling etc. Hopefully the senosr isnt dead then, ive only had it running for a total of about 5-10mins so far. I think the best bet is to connect up my wideband and go from there :D
Does it have its own dedicated lambda input?
the std ECU will normally deal with the lambda feedback, i suspect there is something off in the Mapecu base map,
as said i would be inclined to weld another boss in the 1st decat pipe for the wide band.
If I was to guess I'd say the MAP ECU isn't doing anything and the 550cc injectors are being treated as 440's by the stock ECU and so you're overfueling...
It's might not be doing anything because of a wiring fault or a problem with it's map.
it's a uk car with 550's,
so the stock ecu should handle the idle as it's closed loop. BUT also at cold start the stock ecu puts in a hell of a lot more fuel
but the map ecu 'could' be trying to add more.( depends on the map)
until the wideband is correctly wired in, Martin won't be able to find out what is going on.
The Map ecu doesn't adjust by af/r's like the emanage, only by what you tell it to do in the map. so you need to log runs & adjust where necessary.The Wideband needs to be linked to the Map ecu so you can read what's going on with the software and for logging purposes.
I've run mine for the last 2 years.....it's not bad once you get your head around it:)
an update.
had an email of Marty, he pointed out something simple, that id missed :) Thanks Marty :thumbs:
My map ecu wasnt seeing a vaccum when the car was ticking over, it was sitting at 0, so i had either a tangle in my vaccum hose going to the map ecu, or it had come off in the engine bay. Sure enough, it had come off :oops:. Put it back on and its ticking over 100% better :D afr's are still a bit high though it was sitting at 15, until i clicked a screen shot ;) going to plumb the wideband in this afternoon and see if that brings it down to perfect :D
an update.
No probs Martin, sometimes its the simple things :-)
Marty
i know, i never even thought of looking at that, was thinking the worst....;)
Thanks again mate :thumbs:
ive just got to get the map right now, need to get myself a laptop and get the bugger on the road for some mapping :D
wideband is going in 1st though,
wheres the best way to run the cable in to the engine bay? it has a fairly chunky plug on the end so i cant squeeze it through any small gaps..
