Homer Posted December 14, 2006 Share Posted December 14, 2006 From previous posts it appears that this can be simply unplugged and removed on a manual car without any further issue, after fitting RLTC However, if I don't have RLTC and just want the thing out of the footwell, is it okay to simply remove it? Quote Link to comment Share on other sites More sharing options...
SimonB Posted December 14, 2006 Share Posted December 14, 2006 Yep. You might get the trac warning light on, can't remember now. If so just take the bulb out. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 14, 2006 Share Posted December 14, 2006 Yep. You might get the trac warning light on, can't remember now. If so just take the bulb out. In which cluster is the trac warning bulb, or is it the one on the fuel guage area? Quote Link to comment Share on other sites More sharing options...
Ian C Posted December 14, 2006 Share Posted December 14, 2006 Slip Cont Off. It doesn't flash on a facelift if you junk the whole ECU, not so sure about a prefacelift. -Ian Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 14, 2006 Share Posted December 14, 2006 I removed mine at the same time as my ECU, but i have no power to it yet. I may well remove the bulb while the dash is off. Quote Link to comment Share on other sites More sharing options...
