RX-7 Knowledge?
DannoSupra
  • 4 weeks later...
Not starting when warm is a sign of poor compression on a rotary engine (ie when everything has expanded to operating temps there is little or no compression - but starting when cold is ok)
first thing most specialists will do is a compression test as this is a good indicator of the engine wear
i think you can do this at home with a compression tester but you need to take an average reading the procedure should be up on mazda rotary club as will the tollerance values
good luck mate:d - my best mate life was ruined by a 7 i dont think he will ever recover LOL:) hes still rebuilding it!
