DArby Posted July 27, 2001 Share Posted July 27, 2001 Had the bonnet up today - rare occurance... Up in the top right above the brake system, is a black box with 3 pipes going into it - brake pipes i assume. As i went to close the bonnet (it had been open for about 1hr) - i could here this fast fairly quite ticking sound. If i wiggled one of the pipes it stopped. I gave everything a wiggle and could stop it, but as soon as i let go it started again. Theres no leaks visible, cracks/breaks etc.... Any help appreciated. Dean.. (UK car by the way) Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted July 27, 2001 Share Posted July 27, 2001 Sounds like the Carbon cannister to me. Black with three hoses going in the top. It's supposed to filter off noxious emmisions from a few places, one of them being petrol fumes from the tank. Not sure why it should be ticking though, unless it was just very hot, what with the recent weather. Anybody else know why it ticked ? Quote Link to comment Share on other sites More sharing options...
Doughie Posted July 27, 2001 Share Posted July 27, 2001 might be a bomb. RUN DEAN F*CKING RUUUUUUUUUUUUUNNN!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Phil Wall Posted July 27, 2001 Share Posted July 27, 2001 Dean Toyota intended the UK cars to be main dealer service only. You are not supposed to open the bonnet. The sound you heard was the service charge meter as it calculated the bill you receive at the end of each service.:biggrin: Quote Link to comment Share on other sites More sharing options...
Paul Booth Posted July 28, 2001 Share Posted July 28, 2001 and while we're all in a silly mood.... you stop it by turning up the radio/CD player Quote Link to comment Share on other sites More sharing options...
Guest Ash Posted July 28, 2001 Share Posted July 28, 2001 That's normal, they do make a tick-ticking noise occasionally. It's just venting pressure back from the fuel-tank through a one-way valve. Depending on actual pressure-differentials this valve can sometimes tend to flutter. Yours, J Quote Link to comment Share on other sites More sharing options...
Paul Booth Posted July 28, 2001 Share Posted July 28, 2001 Is this a UK spec thing only? My fuel cap sometimes jumps off into my hand when I unscrew it. Quote Link to comment Share on other sites More sharing options...
Guest Ash Posted July 28, 2001 Share Posted July 28, 2001 No, both the J-spec and UK-spec have the same system. A little pressure in the tank is normal too. Yours, J Quote Link to comment Share on other sites More sharing options...
Alex Posted July 31, 2001 Share Posted July 31, 2001 I concer.... mine does it too! Bit off putting but when you've heard more than one MKIV do it you can relax more! Quote Link to comment Share on other sites More sharing options...
