pistonbroke Posted December 12, 2006 Share Posted December 12, 2006 Searched but found nothing, so here goes. I get this annoying residue build up on my radiator pipe every few days, it seems to be coming from the radiator fan so I'm a bit worried that it could be leaking coolant from somewhere and flicking off the fan onto this pipe. Thing is, I've not lost coolant as far as I can see and was wondering if anyone else with a chrome rad pipe gets the same residue. See pics for details Link to comment Share on other sites More sharing options...
Jake Posted December 12, 2006 Share Posted December 12, 2006 I think the viscous coupling is on it's way out. Has it seized yet? Can you spin the fan manually when the engine is off? Link to comment Share on other sites More sharing options...
pistonbroke Posted December 12, 2006 Author Share Posted December 12, 2006 Nope, spins freely, what gives you the impression its the coupling? Usually, when the viscous coupling goes, you get a loud whooshing noise where the fan is spinning too fast. Link to comment Share on other sites More sharing options...
Jake Posted December 12, 2006 Share Posted December 12, 2006 Nope, spins freely, what gives you the impression its the coupling? Isn't the coupling filled with white liquid like that? Mine was. It doesn't look much like coolant, does it? Usually, when the viscous coupling goes, you get a loud whooshing noise where the fan is spinning too fast.I would have thought that would be when it's completely fooked and has seized up, rather than when it's started leaking. Dunno mate, just suggesting a possibility other than a coolant leak you can't find Link to comment Share on other sites More sharing options...
sdavies Posted December 12, 2006 Share Posted December 12, 2006 That does indeed look like something creeping up the fan blades I have seen this before, pretty much as Jake describes and it was the fan fooked. Link to comment Share on other sites More sharing options...
pistonbroke Posted December 12, 2006 Author Share Posted December 12, 2006 Ok, how much is that bad boy gonna cost me then? Link to comment Share on other sites More sharing options...
TLicense Posted December 12, 2006 Share Posted December 12, 2006 About £170 in parts IIRC. It's real easy to do yourself, so I would do that and save the labour cost, otherwise I think it'll take about 30-40 mins for a garage to do, so I would expect about an hours labour cost. Link to comment Share on other sites More sharing options...
RICHARDA Posted December 12, 2006 Share Posted December 12, 2006 Pistonbroke I had something that looked very similar to your pics. Like you I had a shiny top rad pipe with silicon hosing. Just try tightening the clips up tighter, as in my case the residue was dried on coolant escaping from the hose nearest the block. HTH Rich Link to comment Share on other sites More sharing options...
pistonbroke Posted December 12, 2006 Author Share Posted December 12, 2006 Right, I've been out there during the day, the residue has a slight pink to it, so I'm sure its coolant, I tightened the jubilee clips and one of them sheared I need to find somewhere that does the thicker ones. Link to comment Share on other sites More sharing options...
uk-rich Posted December 12, 2006 Share Posted December 12, 2006 get some mikalor clamps, you will not snap them Link to comment Share on other sites More sharing options...
SimonB Posted December 12, 2006 Share Posted December 12, 2006 Pistonbroke I had something that looked very similar to your pics. Like you I had a shiny top rad pipe with silicon hosing. Just try tightening the clips up tighter, as in my case the residue was dried on coolant escaping from the hose nearest the block. HTH Rich Same thing here, it will be coolant coming out from the coupling furthest away from the rad. It then drips down onto the fan and gets splattered up there. I had to do mine up pretty damn tight to stop it seeping - seems to be worse with the shiny pipe. Link to comment Share on other sites More sharing options...
pistonbroke Posted December 12, 2006 Author Share Posted December 12, 2006 I've found a site that does them but don'e know what size to get, can anyone help.? Link to comment Share on other sites More sharing options...
uk-rich Posted December 12, 2006 Share Posted December 12, 2006 envy will be able to tell you the size you need Link to comment Share on other sites More sharing options...
pistonbroke Posted December 12, 2006 Author Share Posted December 12, 2006 Nice one, thanks for all your help people. Much appreciated. Link to comment Share on other sites More sharing options...
