Will a TT autobox fit into a Supra?
RedM
if it were me and i needed to use the supra to pick it up i would remove the passenger seat (x4 bolts 15mins work) and then pad out the floor and footwell a little and put it in there.........if it'll fit! pretty sure it will......may have to lit the prop end up onto the rear seat but i doubt it.......
Remove the back seat - then you can take the missus with you to help carry it ;)
She isn't coming. Too early a start and she'd only be bored.
Where you getting it done Martin? who is swapping it?
Signature reveals all. ;)
Mine sat in the boot along with the diff, the prop, shifter and a few other bits and bobs :D
Is that the boot on a Supra or something larger?
