hadyn Posted December 10, 2006 Share Posted December 10, 2006 Ive just been looking at the scanned service manual instructions for doing an autobox change (not flush) : Is that basically all you have to do with 2 litres of type IV? Seems simple enough... Quote Link to comment Share on other sites More sharing options...
Gamer Posted December 10, 2006 Share Posted December 10, 2006 Correct Quote Link to comment Share on other sites More sharing options...
hadyn Posted December 10, 2006 Author Share Posted December 10, 2006 Can an idiot like me do it? Quote Link to comment Share on other sites More sharing options...
Gamer Posted December 10, 2006 Share Posted December 10, 2006 Correct again Just make sure you do not overfill it. Quote Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted December 10, 2006 Share Posted December 10, 2006 Make sure you add new gearbox oil through the correct dipstick and not the engine oil dipstick or you really will be a DIPSTICK . :d Quote Link to comment Share on other sites More sharing options...
hadyn Posted December 10, 2006 Author Share Posted December 10, 2006 lmao Quote Link to comment Share on other sites More sharing options...
JohnA Posted December 11, 2006 Share Posted December 11, 2006 It's a good idea to also clean the filtering mesh that lives inside that little sump (especially if you haven't got indications that it has ever been done in the past) Quote Link to comment Share on other sites More sharing options...
hadyn Posted December 17, 2006 Author Share Posted December 17, 2006 Did this today very easy. Think I put about 1.7 litres back in - is that OK? Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted March 19, 2015 Share Posted March 19, 2015 Good read Quote Link to comment Share on other sites More sharing options...
Annabella Posted July 16, 2016 Share Posted July 16, 2016 Managed to do mine today at last, stopped raining! Pretty easy, just need a 14mm socket and wrench, rags, leak proof tarp, (as you will spill a bit) plastic empty oil can with a side cut out, jack and axle stand. I used toyota ATF DIII. Jack up and use an axle stand, I keep the jack under too, taking a small amount of the pressure, and bricks behind rear wheels (just in case!) You need and Undo the nut that was here, 14mm suited. Making sure drained into: Dont forget to put the nut back on, dont over tighten! Lower your car etc, take this dipstick out stick a rag around Fill with this, I put 1.2 L in then backed into garage (garage is level), changed gear etc. warmed it up a bit and topped up some more. Went for a little trip out and topped up some more when back. Hope this helps - some of the pics aren't that great! Quote Link to comment Share on other sites More sharing options...
peter richards Posted July 16, 2016 Share Posted July 16, 2016 (edited) yep did mine in the winter with the help of david p , gears was clunking a bit before , so put about 8 litres through it , now it smooth , done the diff and the power steering Edited July 17, 2016 by peter richards (see edit history) Quote Link to comment Share on other sites More sharing options...
Annabella Posted July 16, 2016 Share Posted July 16, 2016 Thanks you've just created a new job to do, the diff Quote Link to comment Share on other sites More sharing options...
peter richards Posted July 17, 2016 Share Posted July 17, 2016 dont think any of mine had ever been changed , the diff was a sludge , only thing ive got to is the brake fluid , but cant do that on my own Quote Link to comment Share on other sites More sharing options...
The Raven Posted July 17, 2016 Share Posted July 17, 2016 Did the diff the other day. Having never done it before it was quite easy. Remember to take off the fill first just incase it don't want to come off and you have emptied the diff Quote Link to comment Share on other sites More sharing options...
David P Posted July 17, 2016 Share Posted July 17, 2016 yep did mine in the winter with the help of peter p , gears was clunking a bit before , so put about 8 litres through it , now it smooth , done the diff and the power steering That was nice of him? Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 17, 2016 Share Posted July 17, 2016 dont think any of mine had ever been changed , the diff was a sludge , only thing ive got to is the brake fluid , but cant do that on my own you can with a vacuum bleader Quote Link to comment Share on other sites More sharing options...
peter richards Posted July 17, 2016 Share Posted July 17, 2016 havnt got one dunk , just cleaned a clean car lol Quote Link to comment Share on other sites More sharing options...
peter richards Posted July 17, 2016 Share Posted July 17, 2016 That was nice of him? ooooopppps sorry david Quote Link to comment Share on other sites More sharing options...
