What is BPU?
Guest chris.mcd22
Guest chris.mcd22
The jspec's wastegate is too small to handle the increase in boost. Therefore, after decatting (removing the back pressure from the exhuast system) boost runs away to crazy levels - hence the need for a restrictor ring in the exhuast to hold it at a sensible level.
The UK spec has a larger wastegate which CAN handle the increase in boost and will keep it below 0.9bar (ish). To raise boost past the wastegate level you need a boost controller (Or do it the poor mans way with a bleed valve)
Ah ok cool cool. Thanks for the info.
How does everyone pass their mot after they have decatted ?
Decatting is an mot failure is it not?
Guest chris.mcd22
Ah ok.
You guys find garages that are friendly? Most here are full of cowboys trying to get the most money possbile out of you.
