hks clutch component problem, help needed urgently!
fat_controller
The UK and Jap cars have the same gearbox and clutch fittings. If the UK parts don't fit it's likely to be due to the clutch thats been installed. Probably best to speak to one of the HKS dealers for advice (MVP and Whifbitz are the ones here I think)
Taken from the MVP site:
HKS Twin Disk for 1993-98 Supra Twin Turbo
Part # HK 2604-RT004
This kit includes a lightened flywheel and the twin disk that has come so recommended from supras. What kind of difference does this lightened flywheel make? Your stock flywheel, by itself, weight 34 pounds. This awesome clutch including the twin disks, pressure plate, & lightened flywheel weighs ONLY 34 pounds! The difference is huge! This clutch is rated to hold 600RWHP & torque. Please note that you must purchase several parts from the 3rd generation supra in order for this clutch to work. We know that sounds odd, but yes, you do use several parts from the 3rd generation supra as HKS had intended it. For your convenience, we stock all these parts. We call this package the "Toyota - HKS - Parts for Twin & Triple HKS Clutches" and you can purchase it from the 1993-98 Supra Clutch page. This package also includes special flywheel bolts and a special throwout bearing.
The same is true for the HKS triple plate.
I am interested to know about this as well as I have just purchased an HKS clutch.
all the parts for a MA70 pull type clutch are avaiable from toyota!
at £82 all in retail, if you can get discount happy days
.96152-00450 snap ring
.90363-45012 relece bearing
.90201-71001 washer plate
.90206-72001 wave washer
.90520-45023 snapring,shaft
.90201-45023 washer plate
.31264-14040 spring,clutch thrust cone
.31231-14040 hub,relece bearing
So this is the parts list needed to fit the HKS twin/triple clutches ?
What about the flywheel bolts ?
Sorry for being thick. :)
