need restrictor ring diameter
Guest RX-2jz
Guest RX-2jz
i've done my searches and didn't find a post that just straight out tells the diameter of the restrictor ring. i'm in the US and need a ring asap...so i was just going to make one. the engine is a j-spec that has been installed in FD Rx-7. the twins are only going to be on for a very short while until the single arrives, but i don't want to worry about boost creep while they are on. can somebody tell me a good size to start with?
thanks,
mikey
Guest RX-2jz
Originally posted by Jake
52mm or 2'' near as dammit.
I believe you Merkins like your measurements in inches, right?
haha thanks man!...that was fast! yeah inches would be the norm over here. i don't like it, but i guess i gotta use it :p
thanks again,
mikey
