JonW Posted December 7, 2006 Share Posted December 7, 2006 Recently had my GEO done, and I'm very pleased with the results. However when I picked the car up the mechanic said 'It's been lowered hasn't it?' Now as far as I know it's standard height. Is there an easy way to tell?? Quote Link to comment Share on other sites More sharing options...
Ian W Posted December 7, 2006 Share Posted December 7, 2006 yes. does it have the standard shocks and springs on? if you can't identify them then try measuring the ride height from ground to wheel arch and the gap between the tyre top and arch. this will give some indication if we can compare it to a car that we know for definite is at stock ride height. Quote Link to comment Share on other sites More sharing options...
JonW Posted December 7, 2006 Author Share Posted December 7, 2006 I assumed that the shocks and springs were standard. I'm not really able to check. I will take the suggested measurements. Any idea what they should be as standard? Cheers Quote Link to comment Share on other sites More sharing options...
Ian W Posted December 7, 2006 Share Posted December 7, 2006 I assumed that the shocks and springs were standard. I'm not really able to check. I will take the suggested measurements. Any idea what they should be as standard? Cheers i would have been able to tell you but my car with stock suspension has gone i'm afraid. someone will be able to tell you or take a look at theirs. do you have a pic? EDIT: just looked in your garage, looks standard ride height to me mate. Quote Link to comment Share on other sites More sharing options...
rovervi Posted December 7, 2006 Share Posted December 7, 2006 i would have been able to tell you but my car with stock suspension has gone i'm afraid. someone will be able to tell you or take a look at theirs. do you have a pic? I have had people say this and as far as i know mine is standard and not lowered, would be interested to know standard measurements, also, if not too cheaky how much was full Geo setup Quote Link to comment Share on other sites More sharing options...
JonW Posted December 7, 2006 Author Share Posted December 7, 2006 The cost was £76.80 incl VAT. This included the check and any adjustments needed. If they need to work on the car for over 90 minutes then they charge £15 + Vat per extra 30 minutes. Mine needed several changes but still fell within the 90 minutes. Quote Link to comment Share on other sites More sharing options...
uk-rich Posted December 7, 2006 Share Posted December 7, 2006 do you mean tracking check Quote Link to comment Share on other sites More sharing options...
rovervi Posted December 7, 2006 Share Posted December 7, 2006 so did they do the camber adjustment etc Quote Link to comment Share on other sites More sharing options...
Ian W Posted December 7, 2006 Share Posted December 7, 2006 do you mean tracking check I would bloody well hope not! £76.80 for a tracking check?! although i know what you mean, that is quite cheap for a full geo setup. Quote Link to comment Share on other sites More sharing options...
JonW Posted December 7, 2006 Author Share Posted December 7, 2006 Full geometry check and adjustment back to Toyota standard settings. Quote Link to comment Share on other sites More sharing options...
GT5500 Posted December 7, 2006 Share Posted December 7, 2006 Don't mean to sound cynical but what do they actually change for £76, I mean to check and align a subframe is quite a big job, but equally tracking is quite easy. So what do they actually do to car? and also if it was set back to Toyota setting why did they think it was lowered? Quote Link to comment Share on other sites More sharing options...
JonW Posted December 7, 2006 Author Share Posted December 7, 2006 They checked the camber, caster & toe. From what I can remember the toe (which I think is tracking, I am so non technical it's not funny) was out and adjusted, as was the camber. I will get the print out and tell you exactly what adjustments were made if you're interested. Why are you cynical? Is it because it wasn't £200?? If so I called several places and got a few similar quotes. The place I finally went to was recommended to me by my mechanic who had recently had his 500bhp RX7 worked on by the same people. His car is a track car and he was more than pleased with the results. Quote Link to comment Share on other sites More sharing options...
GT5500 Posted December 8, 2006 Share Posted December 8, 2006 They checked the camber, caster & toe. From what I can remember the toe (which I think is tracking, I am so non technical it's not funny) was out and adjusted, as was the camber. I will get the print out and tell you exactly what adjustments were made if you're interested. Why are you cynical? Is it because it wasn't £200?? If so I called several places and got a few similar quotes. The place I finally went to was recommended to me by my mechanic who had recently had his 500bhp RX7 worked on by the same people. His car is a track car and he was more than pleased with the results. Wel I am a bit cynical because of the price but I was a bit curious of what they adjusted? People always talk of garages adjusting camber, toe and castor but I have rarely seen adjustments for most of these things thats why I was wondering what they adjusted. Toe is easy, thats done by the track rod ends, but how did they do the castor? the other thing that worried me was how did they set it to the Toyota settings if they weren't even sure of the ride height as that would drastically affect the settings. Quote Link to comment Share on other sites More sharing options...
Homer Posted December 8, 2006 Share Posted December 8, 2006 Off topic: Jon, Where did you get this done? Was it that place oposite TvMOT's? Dave mentioned today that club member had their supra done there... Quote Link to comment Share on other sites More sharing options...
JonW Posted December 8, 2006 Author Share Posted December 8, 2006 Yeah that was me. The place is called Wigmore Autos, it's about half a mile down the road from Dave's place. I answer to the question about how they did the settings without knowing if it was lowered. I assume they used the toyota settings regardless as that's what I'd asked for. The mechanic just asked out of curiosity because he thought the ride seemed firm!!! Quote Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted December 8, 2006 Share Posted December 8, 2006 Im wanting my geo checking and setting up back to original . Anyone know of any places in the yorkshire area ? does miami-gt do this type of thing ? Quote Link to comment Share on other sites More sharing options...
