Power steering noise
Golddigga
  • 2 weeks later...
Ok - I had all of the fluid levels on the car checked and the PAS fluid was a bit low so it was topped up. It was also lock-to-locked to bleed the system?
Following this I have not moved the car out of my garage for the last week and a half or so. When I got the car out last night, on start up I could hear the power steering. When the car gets warm the noise disappears.
Is it worth trying to bleed the system again and clean the PAS reservoir or is it worth booking the car back in to have the PAS taken apart to see what's wrong?
My mechanic says that the system could have an internal leak? There is no fluid coming out under the car that I can see - somebody mentioned to me a reseal and bearing set - could this be the answer?
I want to try all alternatives before considering a new rack.
Any info would be helpful!!
