2uz 4.7L TT Install
Nic
That is a very mean looker. You're going to terrorise the neighbourhood in that, especially with those airhorns. Well done indeed Eric :thumbs:
Now for goodness sake stop messing about with it and finish my engine!! :D
Thannks Ed! We should be ready to go this week. The last of the accessories are being refinished and installed. :)
Eric
  • Replies 622
Posted Images
Does nobody on here fancy going for the V8-TT instead of the single route. :)
That's somthing i am seriously considering myself actually. Ive been down the V12 install route on one of my other vehicles.
So i am keeping a very keen eye on this and the Dyno sheets when its made available.
I would like a proper breakdown of costs though, including install and complete setup etc.
Great work guys.
Those deep dish are mean. Whats the offset? :D
Hi Ian,
The hose is close but it's handling the heat well so far. The steel tubing goes far into each silicon end to give it some rigidity. The area directly over the coated piping is the steel portion of the radiator hose, so that's good news there. It'll be one of those things we'll have to keep an eye on.
Thanks!
Eric
  • 2 weeks later...
Some first impressions bearing in mind that I'm not in the boost and not revving past 4K right now.
One word.... torque. Just with a trip around the block, there's already a noticable difference. I have a Sp400 (3 speed GM trans, with a 3400 converter), and when in first gear the converter flashes, but when the throttle is stabbed in second gear at 1500rpm, the car lunges forward hard. It's totally different from a 2jz. :) This motor is torquey. :)
Eric
I'm guessing it means the TC slips? And the extra torque means you get more drive - lunges forward?
Bingo. :) It's a relatively low 3400 stall, so as the throttle pressed in first gear, the converter jumps to the stall. In second gear, it doesn't flash so fast, the converter "hooks", and the car lunges forward. It's a crazy feeling coming from a Supra :) Torque down low? Yes :)
Eric
Complete list of mods :)
Mods are:
Engine:
4.7L iron block 2uzfe V8
TTC Performance motor mounts
TTC Performance billet water pump pulley cover
TTC Performance 214, 214 camshafts
Ferrea 36mm intake, 30mm exhaust valves
TTC Performance single wind valve springs
Pauter 2uzfe rods
Ross pistons
Total seal rings
ARP head/main studs
Cometic head gaskets
TTC Performance intake manifold
Q45 throttle body
extensive exhaust porting
TTC Performance oil filter relocation
TTC Performance fuel rail kit
750cc Lucas high impedance injectors
Twin Zirgo 14" fans
custom 2.5" core radiator
custom raditor tubing
TTC Performance 3" catch can
TTC Performance 2" radiator overflow can
TTC Performance billet triple pump hanger
Earls Prolite 350 lines throughout
Earls 85 micron filters
Dual OEM TT fuel pumps
Aeromotive FPR, polished
Link G3 Plus EMS
NZEFI plug n' play harness
Transmission
Sp400 stage 2
Lexus SC400 bellhousing
Pro Torque 3400 stall converter
B&M ratchet shifter full height
one piece driveshaft w/ billet do-nut
OEM 3.76:1 auto LSD
Lokar remote dipstick
Stock 2uzfe flexplate/reinforced
12" cooler/ 12" Zirgo fan
powdercoated subframe
Suspension wheels, brakes
TRD big assed sway bar fr/ stock swaybar rear
Tein CS coilovers
R2 bushings
Work Equip 18x11fr, 18x13 rear, -7 offset
BFG KD 295-35-18fr. BFG DR 345-35-18 rear
Rotora 14" big brake kit, front and rear
Goodriche black brake lines
ABS delete
Motul 600 fluid
Turbo Kit
.125" thick stainless manifolds, midpipes, Y pipe, and downpipe.
Flexible stainless exhaust
Downpipe section mateed to Supra catback exhaust
Twin Bullseye S256 turbos
Twin stainless filters
Twin Tial 38mm wastegates
Apexi GT exhaust
350z intercooler
2.5" pipes
JGPTC twin Bov's
Body/ interior
Bomex Type II front
Blitz sides
350z fender flares
quilted stainless hood liner
shaved wing holes
shaved antenna
shaved third wiper
Katzkin medium red interior w/ black inserts, every interior panel
Sparco Milanos
body colored dash panels
HID's
Relocated turnsignals
LED taillights
Hella Louds ass horns
Pivot Gekko oil temp, tachometer, oil pressure, engine temp, and boost gauge built into dash
Cyberdyne fuel level, speedo, and fuel pressure gauge in overhead body painted pod
relocated A/C controls, window switches, and ignition
Push button start
Audio
Eclipse AVN 5495
Eclipse SC8635 components (4)
Eclipse 7200 subs (2)
Eclipse X1000 amps (2)
Eclipse X4000 amp
Integrated Ipod
Integrated Sirius tuner
Optima Red Top battery
