Guest Mendoza Posted December 4, 2006 Share Posted December 4, 2006 i want a turbo that i can produce a maximum of 700whp on but that will be running on 500whp most of the time and has the best response/least lag possible I have been recomended the T67 with a .68 a/r I would lke to know what else there is that might accomplish the task also i have decided to go with 256 or 264 cams Link to comment Share on other sites More sharing options...
adi2009 Posted December 4, 2006 Share Posted December 4, 2006 If 700whp is your goal then you would definately need a T67. And if you would want minimum lag then probably a T67DBB (ball bearing). However, *I think* a T61 could produce 500whp and would probably be considerably more responsive than the T67. I ve just purchased a PT61 turbo for a project on my spare engine. Link to comment Share on other sites More sharing options...
Alex Posted December 4, 2006 Share Posted December 4, 2006 Precision T67DBB with a .68a/r on the exhaust housing. Link to comment Share on other sites More sharing options...
tooquicktostop Posted December 4, 2006 Share Posted December 4, 2006 I had the HKS T04Z on my Skyline and it produced 735 BHP at the fly and had a quick spool, IMO anymore on a RWD car is going to be difficult to get the power down ? Link to comment Share on other sites More sharing options...
Guest Mendoza Posted December 4, 2006 Share Posted December 4, 2006 735 at the fly is a bit more than i wanted but good info thanks Link to comment Share on other sites More sharing options...
tooquicktostop Posted December 4, 2006 Share Posted December 4, 2006 735 at the fly is a bit more than i wanted but good info thanks You said 700 WHP in the opening post? Link to comment Share on other sites More sharing options...
Guest Mendoza Posted December 4, 2006 Share Posted December 4, 2006 my apologies i had whp and fly confused for a moment i forgot about parasitic loss in the drive system at what rpm did the T04Z start producing positive boost and when does it reach max boost Link to comment Share on other sites More sharing options...
tooquicktostop Posted December 4, 2006 Share Posted December 4, 2006 my apologies i had whp and fly confused for a moment i forgot about parasitic loss in the drive system at what rpm did the T04Z start producing positive boost and when does it reach max boost Hope this give a better understanding of the TO4Z, this was with a poor intercooler, was replaced just after, but good power curve anyway, this car was awesome Link to comment Share on other sites More sharing options...
Ian C Posted December 4, 2006 Share Posted December 4, 2006 Hope this give a better understanding of the TO4Z, this was with a poor intercooler, was replaced just after, but good power curve anyway, this car was awesome What cams have you got, out of interest? -Ian Link to comment Share on other sites More sharing options...
tooquicktostop Posted December 4, 2006 Share Posted December 4, 2006 What cams have you got, out of interest? -Ian HKS in/ex272 lift 9.6 cam Link to comment Share on other sites More sharing options...
Guest Mendoza Posted December 4, 2006 Share Posted December 4, 2006 so is the same turbo more or less responsive on different sized engines e.g. 2.6L Vs3.0L Link to comment Share on other sites More sharing options...
Nic Posted December 4, 2006 Share Posted December 4, 2006 so is the same turbo more or less responsive on different sized engines e.g. 2.6L Vs3.0L The bigger the engine, the more responsive a given turbo will be. Link to comment Share on other sites More sharing options...
Guest Mendoza Posted December 4, 2006 Share Posted December 4, 2006 so the T04Z Tooquick had on his skyline will be more responsive on a supra because the skyline is a 2.6L and the supra is a 3.0L cool great help (only problem is i haven't bought the car yet just in the planning stages) Link to comment Share on other sites More sharing options...
tooquicktostop Posted December 4, 2006 Share Posted December 4, 2006 so the T04Z Tooquick had on his skyline will be more responsive on a supra because the skyline is a 2.6L and the supra is a 3.0L cool great help (only problem is i haven't bought the car yet just in the planning stages) The R32 was running a stroker 2.7litre FYI, but the supra engine will spool it faster I am told, I am running a HKS T04R on my supra Link to comment Share on other sites More sharing options...
Nic Posted December 4, 2006 Share Posted December 4, 2006 so the T04Z Tooquick had on his skyline will be more responsive on a supra because the skyline is a 2.6L and the supra is a 3.0L cool great help (only problem is i haven't bought the car yet just in the planning stages) Might be worth contacting Supragold, he has an HKS T-04Z on his Supra. Link to comment Share on other sites More sharing options...
Guest Mendoza Posted December 4, 2006 Share Posted December 4, 2006 SupraGold has been duly PMd with more questions than a maths test Tooquick what sort of figures are you making on the T04R rpm for 1st positive boost rpm max boost top hp etc (e.g. anything else you think i might find interesting or useful) Link to comment Share on other sites More sharing options...
Homer Posted December 4, 2006 Share Posted December 4, 2006 SupraGold has been duly PMd with more questions than a maths test Tooquick what sort of figures are you making on the T04R rpm for 1st positive boost rpm max boost top hp etc (e.g. anything else you think i might find interesting or useful) Why have you edited your original post? Now the thread makes no sense. Why are you deciding on cams when you don't even have a turbo chosen? Questions to ask 1st are what ECU, what internals, boost, fuel, gearbox, etc.... Link to comment Share on other sites More sharing options...
Guest Mendoza Posted December 4, 2006 Share Posted December 4, 2006 I edited to correct a mistake I made in the a/r of the turbo in the original post I haven't 'decided' on cams yet just narrowed the options baased on my most likely options for turbos i have got a fair idea about ECU's Boost and internals that i want to run already i'm just trying to fill the gaps in my plans also these plans are evolving over a long period of time and they are by no means finalised if things prove to not be able to be done in the manner that i originally envisioned then i will change the plans accordingly Link to comment Share on other sites More sharing options...
Guest Mendoza Posted December 5, 2006 Share Posted December 5, 2006 Homer inotice you are running a T67 DBB turbo what can you tell me about ECU, Internals Boost feul gearbox etc and anything else i might have to consider Link to comment Share on other sites More sharing options...
